Superior 3-4 Shift valve can rotate slightly even with roll pin installed. Normal?
Old Jul 30, 2007 | 11:31 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi, I went to the Superior K015 3-4 full throttle upshift valve today on
my 700R4. I noticed that the machined slot where the retaining roll pin
sits was machined much deeper on the Superior valve than on the stock one.
Whereas the stock valve could not rotate at all, or slide in and out,
with the roll pin installed, the Superior valve can slide in and out slightly,
but it can also rotate very significantly (10 degrees). This seems like
excessive movement of the valve. Has anyone else who has installed the Superior 3-4 upshift valve noticed that it would rotate somewhat even with the roll pin installed? I can slide shim stock in the roll pin groove on the shift valve before sliding it in, but if it is normal movement I'm probably wasting my time.
Old Jul 31, 2007 | 06:02 AM
Pro Built Automatics's Avatar
Re: Superior 3-4 Shift valve can rotate slightly even with roll pin installed. Normal
You should be ok on this.
Old Jul 31, 2007 | 07:07 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I have never seen one not rotate. They are sloppy, but work well. You should be fine.
Old Jul 31, 2007 | 07:30 AM
Car: 2000 BMW M5
THANK YOU GUYS!!! You just eased my worry about the superior 3-4 sleeve.
g.l.mos
Aug 22, 2015 12:02 AM
crazynights
Aug 21, 2015 06:53 AM
86White_T/A305
Aug 17, 2015 12:16 AM
dhonda200
Aug 11, 2015 11:50 PM
