T-56 clutch install problems
Old Aug 11, 2007 | 08:11 PM
91Z28-350's Avatar
I changed the clutch for my 91 w/ a T-56. Now the clutch doesn't disengage.
A couple of things were done. The flywheel (SPEC billet steel) was turned .008", changed the flywheel bolts to a Mr. Gasket set (from local shop, I think it's 912), and I torqued the pressure plate to 15 ft/lbs w/ another 30 degrees.
A question I have regarding the pressure plate torquing methods. I did it in a star pattern and I kept repeating the tightening until no bolts turned when 15 ft/lbs was applied. In other words, I torqued in a star, a little bit at a time, when the click from the wrench came, I moved to the next bolt and kept going that way until I saw no visible movement of the bolt when the click happens. Is this proper? Or should I have stopped after each bolt clicked once, even though the other bolts appear to loosen up?
Another question is if the SPEC flywheel can be turned 0.008"?
Thanks.
rocn7roc
Sep 21, 2021 02:16 PM
Fronzizzle
Aug 17, 2015 02:52 PM
cRoe4
Aug 7, 2015 08:46 PM
rsrmoore
Aug 7, 2015 08:44 PM
