T56 swap need help with clutch pedal
Old Aug 24, 2007 | 04:26 AM
Tenom's Avatar
Car: 1989 GTA
Axle/Gears: 3.23s
This thread https://www.thirdgen.org/forums/tran...tion-need.html says that there should already be an unconnected purple and yellow connector for the clutch safety switch where my pre-existing pedals are. I'm not finding this connector. Where is it located? If I can't find it will I just have to route the wires that came off the auto shifter to the clutch pedal?
Old Aug 24, 2007 | 06:54 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
Re: T56 swap need help with clutch pedal
i finish the t5 swap. you have to run wires over to the old auto saftey switch
Old Aug 24, 2007 | 08:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
my 86 had the extra wires, purple and yellow with a connector on the end, it was hanging on the right side of the pedals, it might be tucked up in the dash a little. There is apparently a patch cable that connects the pedals to the harness, though ive never found one.
Old Aug 24, 2007 | 09:40 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
I found mine behind the drivers kick panel. AFAIK every car came with one even if it was an auto.
Old Aug 24, 2007 | 11:52 PM
Tenom's Avatar
Car: 1989 GTA
Axle/Gears: 3.23s
I still haven't found it, i'm going to do a thorough search tomorrow. On the connector that came off my shifter the two thick wires are green with a white stripe and purple. Will the wires for the harness that's supposedly on the drivers side be the same colors? Also the switch I have on my clutch pedal splits into two different pigtails both with the same color wiring. Anyone know what's up with that?
1992 Trans Am
May 10, 2023 07:19 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
rsrmoore
Aug 7, 2015 08:44 PM
