Need Help Fast!!!!
Old Aug 26, 2007 | 08:14 PM
White25thZ28's Avatar
Car: 92 Z28 Camaro
Axle/Gears: 3.73 posi
Need Help Fast!!!!
OK i put a Zoom High Performance clutch kit in my car today and everything went smoothly until i start the car and try to shift it into a gear... well the trans was in neutral when i took it out and now i can't even get the shifter to move at all no side to side or up and down its just stuck in one position and its in neutral still cause the car rolls back and forth.. what could cause this and what can i do to fix it? i took a pic of a bolt on the outside driverside that was loosened and then tightened back up by my buddy cause he thought it was the fill plug would that cause any of it ? any help is apreciated
Old Aug 26, 2007 | 10:29 PM
Re: Need Help Fast!!!!
1. Which way did you put the throwout bearing onto the fork?
2. The "bolt" is actually the pivot shaft for the linkage that works 5th & reverse. The linkage is held on by a clip. By unscrewing the bolt, the clip was forced off the end of the "bolt", which allowed the linkage to fall apart. The clip and linkage are now laying in the bottom of the transmission. It needs to be pulled out of the car and the cover removed, and the linkage reassembled, before it will work again.
Old Aug 26, 2007 | 10:45 PM
Car: 92 Z28 Camaro
i put the throwout bearing on right but i guess i'll pull the trans again and take that cover off and put the linkage back together.. there any pics of what it is supposed to look like so i can compare ? thanx again
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
