Axle Question
Car: 1992 Chevrolet Camaro RS
Engine: 305 TBI
Transmission: T5 5 Speed
Axle/Gears: 3.08 LS
Axle Question
I have just purchased a 89 5.7 tpi IROC Z with the disc rear and have a question. On the driver side the axle shaft is bent right where the studs go and I need to know whether a drum axle with fit in the rear end. I haven't ran the rpo codes yet so I don't know gearing, splines or none of the info on it. It is a automatic car and has under 100k. Let me know guys as I can't drive it until this is repaired or replaced.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Axle Question
You may have a 9 bolt diff. Only an axle from another 9 bolt will fit.
Engine: 305 TBI
Axle/Gears: 3.08 LS
Re: Axle Question
So it doesn't matter if it is a drum or disc axle so long as it's from a 9 bolt rear. That's what's in it also a 9 bolt.
Car: 87 IROC L98
Re: Axle Question
First of all, good luck finding a replacement axle. 9 bolts are not that common.
The only difference "might" be the center pilot on the axle. A drum and disk axle may have a different diameter pilot. I never checked when I had a 9 bolt and when I had a 10 bolt, I was using aftermarket axles which worked for both drum and disk.
It may be easier and cheaper to find a 10 bolt to put under the car.
Engine: 305 TBI
Axle/Gears: 3.08 LS
Re: Axle Question
Stephen i think that is what's in it. honestly I haven't had the chance to look. I will know for sure tomorrow. I'll get back to you then.
Engine: 305 TBI
Axle/Gears: 3.08 LS
Re: Axle Question
It does have a 2.77 ratio and a 9 bolt cover. D^^^!!! Is it honestly going to be that hard to find one?
Car: 87 IROC L98
Re: Axle Question
Yes. They were only available from 87-89 and only a few models from each year had a 9 bolt. Aftermarket parts are just about non-existent unless you go to Australia.
It is a bit stronger than a 10 bolt but with the lack of any aftermarket parts, it's not worth anything if it needs repair. You "may" luck out and find one in a junk yard.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: Axle Question
just search around for a v6 junker, easy 3.42 gearset.
Engine: 305 TBI
Axle/Gears: 3.08 LS
Re: Axle Question
stephen I found these axle on ebay just now I'm gonna attach a link. Check them out are they right?
http://cgi.ebay.com/ebaymotors/ws/eB...172055315&rd=1
Genopsyde
Oct 7, 2015 08:35 PM
downsouthboy
Aug 29, 2015 11:29 AM
red90IROCls1
Aug 25, 2015 06:56 AM
