Leaking Transmission Fluid
Old Oct 23, 2007 | 09:59 AM
atgrissom21's Avatar
My 1983 Firebird is leaking transmission where a line connects to the transmission. It is a manual. I was wondering if anyone knows what the line or cable or whatever it is is called? It has fittings like a water hose. Does anyone have any idea what this is?
Old Oct 23, 2007 | 10:24 AM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: Leaking Transmission Fluid
Does the line go into your clutch master cylinder. The little reservoir on the drivers side of the firewall and the other end into your slave cylinder on the tranny?
Old Oct 23, 2007 | 10:41 AM
yes thats like it
Do you know what is it called by any chance?
Last edited by atgrissom21; Oct 23, 2007 at 10:44 AM. Reason: Automerged Doublepost
Old Oct 23, 2007 | 01:45 PM
bigj350's Avatar
Take a look at this and see if it helps. Let me know were exactly it is leaking.
Old Oct 23, 2007 | 02:01 PM
Nope that doesn't look like it at all it is just one long line about 4 to 4 and half feet long and it comes out the back of the transmission up to the front of the car to another thing that has a hose going to off it towards the steering wheel. Have any ideas I have been searching all day I can't find nothing.
It is leaking from where the hose hooks up the the transmission but the hose has a spring like thing going inside of the transmission
Last edited by atgrissom21; Oct 23, 2007 at 02:02 PM. Reason: Automerged Doublepost
Old Oct 23, 2007 | 02:06 PM
bigj350's Avatar
Oh, that sounds like you speedometer cable. I believe those have a seal. Probably just needs a new one.
Old Oct 23, 2007 | 02:07 PM
Thanks, I'll check that that out. I hope it is it. As you can tell I don't know much about cars.
Old Oct 23, 2007 | 02:14 PM
bigj350's Avatar
Get yourself a repair Manuel for your car. That will help you out a lot in the long run. Haynes is alright, I've heard chiltons is better though. O'reillys sells both for around 15 or 20 bucks.
LittleFranks
Sep 17, 2015 12:22 PM
RED85TPI
Brakes
Aug 31, 2015 10:29 AM
someone972
Aug 30, 2015 12:52 AM
spaigo
Aug 21, 2015 07:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
