Transmission confusion, please help!
I have a 88 Iroc - 5.7 with a 700r4 (with overdrive). I'm looking to pickup a transmission to rebuild, the one I have still works in the mean time but slips (I was told by 2 trans shops that it needs to be rebuilt). I have seen a trans local to me for $30 - its out of a 89 CK pickup. Will this trans work? what other years of Camaro/Trans Am's will work? Will something out of a 2.5l work? I believe I have a cable driven speedo, or at least it appears that way when I switched the dash out - please help, Im trans stupid!
thanks
Drew
thanks
Drew
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Re: Transmission confusion, please help!
Truck trannies may have longer tailshafts, atl least that is an option w/ Th-400s. Just measure them since the mount location and engine bolt pattern is the same for all non LSX small blocks.
You should be able to use any 700r4 and swap the cable driven speedo assembly in if the one you get is digital.
Axle/Gears: '01 3.42 10 bolt
the tailshaft and housing are the same length on all 2wd 700r4s except the corvette. stick with the '87 and up as they have the better upgrades. one from a 2.5l will not work as the bell patterns are different. it is pretty easy to swap out speedo assemblies if you get the wrong one.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
the corvette housing is different then the f-body. same length but different mounting. as far as the shaft itself goes, i have never measured on of them because i haven't a vette unit apart, but everything i have seen lists a different shaft then the f-bodies. the actual length difference may only be a 1/4".
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
It's a different tailshaft for sure. I was under the impression you could mount a fbody tailshaft if you wanted too, but you still wouldn't get a crossmember mount point.. I don't know why they made a special V casting. When I put my 700R4 up for sale (rebuilt, transgo shift kit, MINT tranny) It took me like a month and a half to sell it because I could only sell it to a vette owner. (who wanted stiff shifts)
-- Joe
okay, am I correct in assuming that as long as I get a 87+ trans out of a non 4x4 V8 vehicle (305/350) I should be safe? I really dont want the hassle of not being able to use my car while the trans is out being rebuilt...plus the fact that I will have to ask a friend to help me twice.
Car: '91 TA vert
Engine: turboLSx
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
bubbaz28
Sep 18, 2015 02:09 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
