b&m shifter
Old Oct 24, 2007 | 03:44 PM
thebird91's Avatar
Car: 91 firebird
Engine: V6
Axle/Gears: stock
b&m shifter
how is the b&m automatic shifter working for everyone?????????
Old Oct 24, 2007 | 04:10 PM
jed5161's Avatar
Car: 88 Trans Am GTA
Engine: 383 Lingenfelter/AFR 670 hp
Transmission: 700r4 3500 stall
Axle/Gears: 3.90 9 inch
Re: b&m shifter
junk it and get a hurst. waste'd too many tranny's because of the damn b&m shifter
Old Oct 24, 2007 | 04:49 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: b&m shifter
had the megashifter for 3 or 4 years and love it. the shifter shouldn't effect the transmission if it is installed correctly.
B&M shift kits on the other hand.......
Old Oct 24, 2007 | 06:01 PM
jed5161's Avatar
Re: b&m shifter
its not nessesarily the shifter themselfs. its more the shift cable. they got some give to em. at least back when i bought em. always had to adjust it. even in our race cars. destroyed one front end of our drag car because the shift cable, shifter was in park, brand new cable took crap and ended up bein in drive after a couple of runs through the gears.
Old Oct 24, 2007 | 07:29 PM
87zjeff's Avatar
Re: b&m shifter
they might have an updated design now. i adjusted mine initially and haven't looked back.
Old Oct 25, 2007 | 10:26 PM
ccook-92-305's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R4 w/transgo 700 shift kit
Axle/Gears: 3.42 posi
Re: b&m shifter
i also have had a B&M Megashifter for about 3 years now it took lots of tweakin and twistin but its been great ever since.
Old Oct 25, 2007 | 10:37 PM
86transamkid86's Avatar
Car: 1986 trans am
Engine: 305 tpi
Transmission: ?
Axle/Gears: 2.73/stoke/soon to be 3.47
Re: b&m shifter
does it go down to 1st,2nd,drive,because i want one but me friends only goes as far as overdrive so i want on that goes all the way down to 1st
Old Oct 26, 2007 | 12:10 AM
FAST LiFE's Avatar
Re: b&m shifter
Had the same Megashifter since 89. Never had to adjust it once everything was set and never had a single problem.
Old Oct 26, 2007 | 05:00 AM
87zjeff's Avatar
Re: b&m shifter
yeah, it goes all the way to first. you have to bring it back to OD, release teh small t-handle, then ratchet it back to 1st.
Old Oct 26, 2007 | 09:11 AM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
Re: b&m shifter
I have the Megashifter and love it. Never had to touch it after initial setup.
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
