Has Anyone tried one of these new tremec transmissions?
Old Dec 10, 2007 | 10:34 PM
83Chevy__Camaro's Avatar
http://www.jegs.com/webapp/wcs/store...0002_943981_-1
Old Dec 11, 2007 | 12:19 PM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Re: Has Anyone tried one of these new tremec transmissions?
Yes, I have the TKO 600 in my car, like it so far. I'd recommend getting it from a place like Forte's though, he has the needed "adapter" pieces for it to fit in a thirdgen. Also, the spohn crossmember is a must. I didn't care for the stock shifter, so I have a Pro 5.0 on it now and its great. The driveshaft will need a different slip yoke and might have to be shortened. Other than that, it seems to be a pretty good tranny so far. I'll let you know if it lives up to the "600" name. hahaha.
Old Dec 11, 2007 | 07:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
I bought my tko600 from fortes, no complaints with them, just dont try to e-mail them, they never answer it. and dont get his offset shifter to relocate it back 2", it bunches up on the rubber boot and pops the trans out of 2nd and 4th. Didnt have to shorten my driveshaft.
I would go with fortes over jegs, he has all the conversion parts.
Old Dec 11, 2007 | 09:03 PM
i was thinking about gettign the t5 replacement since its suppose to be way better but i dont know if there any good
Old Dec 11, 2007 | 09:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
what replacement?
Old Dec 11, 2007 | 10:07 PM
? that link offers a 5 speed tremec...hello.
Old Dec 12, 2007 | 06:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
well i see this
t5 replacement, the jegs link has no t5 replacement, just the tko trans. Yes is a gm style trans, but its not setup for the f-body, you still need an adapter to bolt it up to the stock bell housing, and i dont believe jegs sell it. that all i was getting at
the tko is a great trans, a t56 can be made a lot stronger, but its also more expensive and heavier
Old Dec 12, 2007 | 08:52 PM
what adapter, why wouldnt it fit ?
Old Dec 12, 2007 | 09:45 PM
what about the gforce transmissions then?
Old Dec 13, 2007 | 03:53 PM
Shagwell's Avatar
Car: projects.......
the T5 is a vulnerable trans any way you cut it. If you do a search, you'll find many reasons not to waste your money on "upgrades" for it.
The TKO's are tought trans, but a bit notchy shifting(require clutching). - They do offer a build to order TKO 900, which is tougher than most T56's, except maybe tranzilla which is $8000. - I've heard of a supposed "pro shifted" TKO which can be shifted clutchless....
Old Dec 13, 2007 | 04:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the stock t5 is mounted to the bellhousing rotated like 18 degrees or something, the TKO is made to mount straight up. You could get a Lakewood bellhousing which allows you to mount GM transmissions straight up, but the TKO is not a GM trans, its use by ford, so the pattern is different. Forte's sell his with an aluminum adapter, 1" thick, which bolts to the stock, or lakewood bellhousing, and adapts to the right bolt pattern and puts the trans in the straight up position.
I will agree with shagwell, you need to use the clutch to shift, no power shifting, but IMO the clutch is there for a reason right? And the G-force trans is a waste of money.
Never heard of the TKO 900, sounds like a beast
Old Dec 13, 2007 | 08:34 PM
i like my 5 speed, so there isnt anything i can do except just rebuild it and take it easy on it?
Old Dec 17, 2007 | 10:41 PM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
Why bother? They are fragile and barley hold up to a stock 305. People have given you plenty of 5 spd options here. All it requires is an adapter plate. You will still have a 5spd with the shifter coming out of the center console. The difference being that it won't break and you gan get on your car when you want/need to do so and that it isn't turned at an angle when you look under the car.
I don't see the point in wanting to keep a crappy tranny.
Old Dec 17, 2007 | 11:26 PM
i looked at an install and it doesnt sit where the stock shifter does, you have to modify crap to make it work, if there isnt a true replacement then ill stick with what i got. I dont want to have to monkey **** around with stuff to get it to work
Old Dec 18, 2007 | 09:11 AM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
I'm running an older TKO in my 84 TA that is bolted up to a C4 bell housing and slave cyl. the housing is a direct bolt up
Old Dec 18, 2007 | 11:11 PM
I just wish i didnt have to do any mods, i want to take out my old transmission and bolt the new one up, i like old style linkage, i like using the stock bell housing and not having to move the shifter, i hate large modifications.
Old Dec 20, 2007 | 01:04 AM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Then get a different ****ing hobby
Old Dec 20, 2007 | 12:35 PM
Shagwell's Avatar
TKO's can be had with umpteen million shifter locations, I can't see having to move anything there. As for the bellhousing, IMO, I won't run a stocker in anything. I've blown a couple clutches and I like walking. SFI all the way. - BTW, I have a mechanical clutch, but mine is custom, nothing like the factory stuff. 3200# roller assist borg&beck pressure plate won't have anything to do with fatory linkage or hyd stuff.
//<86TA>\\ - yep, the clutch is there for a reason....staging and shut down....other uses of it just slows you down.
Old Dec 21, 2007 | 10:21 AM
Pat Hall's Avatar
I love it when someone gives a direct, no answer! Btw, another reason it's important to get the Fortes 3rd gen TKO is the fact that they put a longer input shaft in them due to the 1" thick adapter plate. The only thing the shifter on my TKO required to fit in the proper position in the console was a simple, flat piece of steel with two sets of holes drilled in it so you can move the stick back about 2 inches.
Old Dec 21, 2007 | 10:37 AM
racer J's Avatar
Engine: 305 TBI
lol
You could also STOP looking at the TKO. IIRC, a Richmond 5 spd should drop right in. You will however need a Lakewood bellhousing and a Long shifter kit. The shifter kit includes a transmission crossmember mount and torque arm bracket so that nothing else has to be changed.
You have to pay to play regardless if it is longevity or racing.
Old Dec 21, 2007 | 05:41 PM
Car: 89 Formula
Only way I roll my friend if you dont like messing with **** then get outta the car hobby or win the lottery and pay somebody else to do it
topteam54
Oct 6, 2015 12:21 AM
Camaroman
Jan 8, 2003 07:58 AM
duke_mushroom
Sep 6, 2001 02:09 AM
Maverick13
Jul 8, 2001 11:15 AM
Maverick13
Mar 28, 2001 09:26 AM
