I swapped my rear and Now the car does 120 mph in seconds!
Old Dec 16, 2007 | 08:51 PM
goomaan's Avatar
Car: 1987 IROC-Z
Transmission: 700R Auto
Ok now that I got you to open the thread here is my problem.
I recently put a posi 4.10 rear into the car and the pick up is amazing... (yes I know she does top out but the engine swap is slated for June).
The problem is the car now does 120 mph in about 5 seconds. What is the problem you ask. Well the problem is I am only doing about 50 -60mph and the speedo is reading 120.
How do I calibrate the speedo on a '91 Z28? The cluster is all electronic????
Old Dec 16, 2007 | 09:41 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: I swapped my rear and Now the car does 120 mph in seconds!
I was gonna ask where you got this rear from, then I read further... lmao
sorry, no help here but that was too funny not to say something.
Old Dec 16, 2007 | 09:43 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Same as every other 82-92 f-body. You change the plastic speedo gears in the tailshaft of the transmission.
However, since its electronic you need the right part numbers. A search of this forum for "speedo gears" should reveal all.
Old Dec 16, 2007 | 10:06 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
so uhmmm i missed out:
where did he get the rear from ?
Old Dec 16, 2007 | 11:24 PM
performabuilt's Avatar
You will need to recalibrate you pcm if 4l60e and change speedo gears if 700r4 its that simple
Old Dec 17, 2007 | 04:06 AM
codemonkey's Avatar
Car: 84 Trans Am
Engine: 305 HO
Transmission: 700R4 soon to be a TH350
Places to recalibrate PCM:
GM Dealership
Some Tire shops
Most Performance shops that tune
Old Dec 17, 2007 | 05:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The poster mentions a 700R4. Check/call the following website for gear info:
http://www.transmissioncenter.net/sp...n_______va.htm
JamesC
Old Dec 17, 2007 | 07:49 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
4.10's in a 4l60 ... does the gas gauge go down as fast as the speedometer goes up LOL
Old Dec 17, 2007 | 09:35 AM
goomaan's Avatar
Car: 1987 IROC-Z
I only got to drive the car from the shop to my garage. But it cost me a half a tank of gas for a 10 mile drive.....
The tranny is a 700R.
JamesC
What a great site!! Thank you!!!
Jorlain
Aug 24, 2022 05:11 PM
midge54
Dec 27, 2019 04:14 PM
B_Dubya
Aug 26, 2015 05:09 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
