Trans Swap Help
Old Jan 2, 2008 | 02:47 PM
Aaron87's Avatar
Trans Swap Help
I got an 85 Firebird with a 350 HO (330 HP) GM crate engine (I think). It's currently running a 700R4. What would it take to convert it to a manual, and what type of manual could I use? (T56, T5, etc.)
Also, could I use a transmission out of a Mustang or similar?
Old Jan 2, 2008 | 03:09 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Trans Swap Help
Can't use a Mustang piece. Both the T5's are weak (though I'm running a non-WC behind my 350 HO Deluxe. No problems but I'm a Sunday driver). Best bet is probably a Tremec 5 speed or a T56. Search will provide the swap threads you're looking for.
JamesC
Old Jan 2, 2008 | 03:21 PM
Aaron87's Avatar
Re: Trans Swap Help
Any idea what kind of car (or truck) I can get a T56 from? I am looking for the fastest, cheapest (looking to do this for under $300), and easiest install possible. Also, any idea if I have to cut a new hole for the shifter, or I can just use the stock hole from the auto?
Old Jan 2, 2008 | 03:26 PM
JamesC's Avatar
Re: Trans Swap Help
Your budget will be prohibitive (even with a forthgen JY transmission). As an example of some of the equipment you'll require, check the first link and note the prices:
http://www.spohn1.com/?action=shop&pcid=1047
https://www.thirdgen.org/forums/tran...ap-thread.html
JamesC
Old Jan 2, 2008 | 03:39 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Trans Swap Help
trade for a manual trans car unless you can find a complete manual trans 3rd gen donor carbecause you are going ot need alot of parts and have to take alopt apart
pedals assembly, clutch linkage parts
slave master cylinder, and parts
and you need to be very mechanically inclined and have a shop and tools and so on
no one is ever happy with what they have it seems, and manual trans third gen f bodies are extremely common
good luck
Old Jan 2, 2008 | 03:44 PM
Aaron87's Avatar
Re: Trans Swap Help
Well, for some reason I think that idea is scrathed for the time being, at least until I'm willing to spnd more time and money. (I only spent $300 for the car!){It did come with a blown tranny, though...}
BTW- do you have any idea if a stock 700R4 will be able to stand up to what I got, or will it probably die on me if I put it in? (Tried once before with this car, and the tranny went on first test drive. Mechanic friend of mine said it was because I messed up when I installed it)
Old Jan 2, 2008 | 03:48 PM
JamesC's Avatar
Re: Trans Swap Help
Yes, if you don't mess up again
JamesC
Old Jan 2, 2008 | 03:54 PM
Aaron87's Avatar
Re: Trans Swap Help
Now all I gotta do is find the time to get it in.
Thanks a lot for all your help!
(I'm probably going to need a ton more when I actually get down to installation so I don't screw up-I really wanna use this car(It's been sitting for a year and a half!)
Old Jan 4, 2008 | 11:03 PM
hotrodhoney's Avatar
Car: I race:86' I-roc Z
Engine: 350 bored 30 over (355)
Transmission: th400 w/B & M ratching shifter
Axle/Gears: has a 10bolt (for now,will change)
Re: Trans Swap Help
well if u like the factor of the shifting manually all the time, you could just put a shif kit in that requires you to do so that's made for an auto tranny.
good luck,
kelly
Jorlain
Aug 24, 2022 05:11 PM
midge54
Sep 2, 2020 07:13 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
