T5 trans-bell mount bolts
Old Jan 21, 2008 | 06:52 PM
85_SS's Avatar
Car: 1985 Monte Carlo SS
Engine: 5.7L
Transmission: WC T-5
Axle/Gears: 3.73:1
Are the stock T5 transmission to bellhousing mounting bolts have a torx head?
I had to buy bolts from the hardware store and you can't get the socket on a hex socket very well for the upper PS bolt due to the case (had to thread in most of it by hand - will not be fun to get out after it's been in there a while. I came across something that suggested that they should maybe be torx bolts so I will have to see if I can find some.
Old Jan 21, 2008 | 06:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: T5 trans-bell mount bolts
maybe a allen head bolt? make sure its a hard bolt.
Old Jan 23, 2008 | 06:11 AM
Pat Hall's Avatar
Yeah, the stock T5 mounting bolts are both. They're hex head with an internal torx. 15 mm hex IIRC, and like T45 or T50 internal torx. Of course if you can't find any stock ones, I'd just do as suggested above and grab some grade 8, internal hex style bolts. Those would do the job quite nicely.
Old Jan 23, 2008 | 06:40 AM
85_SS's Avatar
Engine: 5.7L
Axle/Gears: 3.73:1
Thanks guys - I ordered some yesterday from GM. A little pricey at $6.50 or so a piece, but not too bad.
Terrell351
Jun 13, 2021 01:13 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Elliswon
Aug 10, 2015 12:33 PM
