29x12.5 tires fit!
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
29x12.5 tires fit!
Some minor rubbing on the inside. I havent cut or beat anything yet. They touched the fender on the right side, but the rear is slightly off center. So after I fix that and roll the inside lip, it should be perfect. I still smoke these tires in 2nd gear with 2.73 gears. And I mean smoke.
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: 29x12.5 tires fit!
looking good, i cant wait to get some taller and wider tires for mine. what are the specs on the wheels ur runnin? i have some 26x10.50-15 on a pair of weld prostars but the just look to dinky.
Car: 91 rs
Axle/Gears: 3.50 9"
15x10 draglites 5.5 backspacing. I still had an inch to the control arms, so a little more backspacing could fit a bit wider tire.
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
HHaaaaaaaaaa Looks like my garage!! boobie traps and parts and tools everywhere!! Love it..tires look good!!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Oh, A 12.5 DOT tire not a 12.5 slick. Different sizes.
The rear is always off center. It's just more noticeable with big tires.
Car: 91 rs
Axle/Gears: 3.50 9"
I didnt know that, whats the difference? Yea garage is a mess. My motivation during the winter is limited. And I need another one just for all the junk I dont want to throw out.
Car: 87 IROC L98
DOT width is measured across the sidewall. Slicks are measured across the tread. Seeing tread on your tires, they must be a DOT tire.
Looking at the tread, I'd guess MT Sportsman Pro tires. The 29 x 12.5 only has 10" of tread when mounted on a 10" rim and has a sidewall width of 13". MT doesn't have a similar sized slick.
Technically, you only have a 10" tire since that's the width of the tread.
This is what the wheel opening looked like when I had a 29.5 x 10.5 slick on the car. The back of the opening was trimmed for clearance. The rear was sitting high because there's so much weight removed and I was using V6 springs.
This is the difference between the 29.5 x 10.5 tires I had on the car and the 32 x 14 I now have on the car although these pics show some worn out Hoosier slicks and I now use MT.
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
holy wow. wide tires i like
what is the max width of tire can you put on a 9x15 rim? would a 10.5 slick work on that? thats what the rims i have on my car right now.
American outlaw II style rims.
Car: 91 rs
Axle/Gears: 3.50 9"
Holy cow thats a big difference. At the track, I probably wont need much more than a 10 wide. I havent measured my tires, but Im guessing I could fit an 11 inch slick back there.
That sounds right on the tire I have, I got them used to see how a tire that big would hook. They dont. I know et streets hook well but dont last long. Ill have to look around for a better middle of the road tire. Sidewall is a little big for the road as well.
Your car is freakin wicked man. Nice video. Where the heck are you at, Alaska?
Street Lethal
Apr 30, 2019 12:14 PM
ambainb
Apr 25, 2016 09:21 PM
