picking the right tranny
Old Feb 11, 2008 | 09:54 PM
antosh's Avatar
Car: 1991 camaro z28
Engine: 5.7 TPI L98
Axle/Gears: stock
first of all i have heard that the LS 6 speeds use a different input shaft and won't work on a L98.
plus i also am looking into add more hp into my car becasue i know that the t-56 is only rated for around 400 hp and i would like to break that soon
so with all that what would be the best for my car which is a 1991 z28 with the 5.7 l98???
Old Feb 13, 2008 | 09:58 PM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
Re: picking the right tranny
anybody??
Old Feb 13, 2008 | 10:00 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
you are right, an ls1 t56 has a different bolt pattern, just get an lt1 4th gen t56
Old Feb 13, 2008 | 10:26 PM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
and the lt1 t-56 which is out of a 93 to 97 f boby will be the best fit for my car
and what is the rated hp on that transmission?/
Old Feb 13, 2008 | 10:36 PM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
A t-56 can handle more than 400hp. Hell mine held 600rwhp then i had it build cuz I had so much downtime waiting on pistions and new turbos. And so far we took it to the 900rwhp range. car has a 12bolt with 3.42posi and a clutch like a light-switch. I killed to clutches in the fist 90days I got the car new. Cuz I never drove a stick. But the trans held even with me grinding gears. And even when I was forcing into gears that where not there. No bent forks?
Old Feb 13, 2008 | 10:49 PM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
well thats makes better to by becasue i was hearing that it goes up to 400hp but if your help to 600 then what i am going to do should hold up to cause i am trying to climb up to a little over 400 and its a good thing i already know how to drive a stick
Old Feb 13, 2008 | 11:10 PM
2fast4u92z's Avatar
Yeah and my other two buddies both twin turbo cars had t-56 one 560-660rwhp and the other 890rwhp. however we killed 10bolts once a week! In fact i think we each killed 2-3 before DTS was nice and gave use the 12bolts.
Old Feb 14, 2008 | 12:00 AM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
yea thats pretty sick but i am not running that much hp so i should be good will the rear end i have right now but if anything happens to it it looks like i am going to also have to invest in a better one
Old Feb 21, 2008 | 05:02 PM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
so has anybody bought a t-56 from a junkyard and if so how much did you pay for it?
grngryoutmyway
Oct 18, 2016 05:48 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
