V8 T-5 in a V-6
Old Mar 6, 2008 | 05:23 AM
photontraveler's Avatar
V8 T-5 in a V-6
Can I use a T-5 out of a V-8 in my V-6 if I use a V-8 clutch plate or do I have to change the input shaft?????????
Old Mar 6, 2008 | 03:42 PM
AmorgetRS's Avatar
Re: V8 T-5 in a V-6
You'll have to change the input shaft.
Old Mar 6, 2008 | 04:18 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: V8 T-5 in a V-6
Changing the input shaft would be one way to do it, another would be to get a disc the appropriate hub and diameter for your V6 plate.
If you want to skip a lot of disassembly and reassembly, the disc is the way to go, if you dont have the means to get your hands on one, PM me I can help you out.
Old Mar 6, 2008 | 04:23 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Re: V8 T-5 in a V-6
Ah here ya go, off the shelf clutch disc, problem solved.
http://store.summitracing.com/partde...5&autoview=sku
Old Mar 6, 2008 | 04:55 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Re: V8 T-5 in a V-6
I think the V8 shaft is shorter.
Old Mar 6, 2008 | 05:22 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Re: V8 T-5 in a V-6
On some V6 T5's the very very end is slightly longer where it goes into the pilot bushing, some have had to grind a very small amount off when using a V6 T5 in a V8, sometimes its not required, at any rate, there will be more than enough of the pilot tip of the input shaft to engage the pilot bushing.
Old Mar 7, 2008 | 04:11 AM
Re: V8 T-5 in a V-6
Thank you. I appreciate your knowledge and quick reply...................it was most helpful.
Old Mar 7, 2008 | 12:13 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: V8 T-5 in a V-6
I did that, too. No problem with the pilot bushing/input shaft issue here...
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
