DANA 44 NEEDED
Car: 1989 TTA
Engine: 3.8 TURBO
Transmission: AUTO
DANA 44 NEEDED
HI ALL, I NEED A DANA 44 FOR A 3RD GEN. 3.31 RATIO, WOULD CONSIDER ANY RATIO THOUGH. AS CLOSE TO LONG ISLAND NY AS POSSIBLE. THANKS
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: DANA 44 NEEDED
You're dreaming. Providing someone even has one that's in good condition and willing to sell it, you'll probably spend less money buying a bolt in 9" or 12 bolt.
Car: 87 IROC L98
Re: DANA 44 NEEDED
You might be able to still find inexpensive ones but changes are it's not in great or good condition regardless of what the seller tells you..
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
Re: DANA 44 NEEDED
Didn't the Dana 44 only come in 1992 Firehawks and as GMPP replacements in a 3.54 ratio?
I remember that Summit had a "clearance" on these for GM/SLP around 1994 or 1995 for $425..... should have bought a truck load of them!
Kevin
Kevin
Car: 89 IROC
Engine: Built 383, Vortech SC
Transmission: Pro-Built 700R4
Axle/Gears: Dana 44, True Trac, 3.54
Re: DANA 44 NEEDED
Yes, they came in Firehawks. Summit cleared them out(from SLP) in 1996. They went for $1500. I still have my reciept.
Car: 1989 TTA
Engine: 3.8 TURBO
Transmission: AUTO
Re: DANA 44 NEEDED
GM PERFORMACE PARTS OFFERED THESE REARS OVER THE COUNTER IN 3 DIFFERENT RATIOS. BACK WHEN THE CARS WERE NEW , IF YOU BLEW YOUR 3RD GEN REAR, THE DEALER OFFERED YOU (FOR AN ADDITIONAL FEE) THE DANA 44 AS A REPLACEMENT FOR THE 9 AND 10 BOLTS.
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Re: DANA 44 NEEDED
I remember when they were listed in the GM performance catalog. I think I still have that catalog laying around somewhere.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: DANA 44 NEEDED
get a moser 9" and call it good. The dana 44 is no where near as strong as an aftermarket 9" ever will be. Not to mention gear changes are super cheap if you ever regear it.
Car: 1989 TTA
Engine: 3.8 TURBO
Transmission: AUTO
Re: DANA 44 NEEDED
DO YOU KNOW A 9 INCH TAKES MORE HORSEPOWER TO SPIN THAN A 12 BOLT OR A DANA. IT HAS THE OFF SET PINION, AND I HAVE HAD TO PUT IN POCKETS IN THE FLOOR FOR PEOPLE BECAUSE THE TORQUE ARM AND THE 9 INCH. THE DANA WORKS FINE SINCE IT WAS ENGINEERED FOR THE CAR. I CAN WAIT A LITTLE UNTIL I FIND ONE. I'LL JUST KEEP BUYING POSI UNITS FOR NOW.
Car: 1984 Z28
Re: DANA 44 NEEDED
whatever makes you sleep better at the end of the day. Funny how hot rod did an article a few years ago with a 9", 12 bolt, and a dana 60 and they all ran within .08 of each other in a mild HP build up.
Car: 87 IROC L98
Re: DANA 44 NEEDED
As for the pinion being offset. My pinion is dead center to the transmission. The pinion is centered and the right axle is a little bit longer than the left which is very common in Ford cars with a 9".
What kind of pockets in the floor? There are many third gens with a direct bolt in 9" diff under the car. It uses all the factory suspension components including the torque arm without any floor modifications.
Car: 1984 Z28
Re: DANA 44 NEEDED
i had to do a little massaging to get my 9" and torque arm to fit but nothing that 3 hammer hits with a rubber dead blow hammer didn't more than clearance for me.
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: DANA 44 NEEDED
i think from what little i know and have read the dana 60 from strange seems to be the most affordable and stronger than a 12 bolt. Not a big fan of paying close to 1K for new third member plus everything else. i think they even said it is stronger than the 9" and it's 100% bolt in w/ no clearance issues. That's what ill be using when i get the cash this summer.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: DANA 44 NEEDED
the dana60 IS NOT a direct bolt in, you have to shorten your driveshaft.
I feel that in the end the 9" is the way to go, yes technically it has a higher power loss than the alternatives, but the aftermarket will take it further than any of the other options.
Im picking up a 9" with a moser aluminum case and tru-trac probably this spring.
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Re: DANA 44 NEEDED
xpndbl3-I would love to read that article, can't find it though.
I remember reading though, the efficiency differences between the 9, 12 bolt, and dana 60. Between the ford and 12 bolt, not much difference. But between the ford and s60, at 600 rwhp, it was like 18 more hp getting to the ground. Kind of substantial, but pita to change gears, and I've heard they are not near as reliable as a ford 9.
I just got a bolt in 9" moser housing for $1050, and picked up a third member for 200 bucks with the gears I wanted and a spool. Tell me you can do better than that.
The guy used a bad choice of words listing it on ebay, so no one found it. I just happened to run across it looking for a set of gears.
I'm taking that thousand bucks I saved on my rear and putting it into MORE POWER. Negates any efficiency loss.
If your breaking 10 bolts that quick, I doubt a dana 44 will hold up for you.
Car: 1989 TTA
Engine: 3.8 TURBO
Transmission: AUTO
Re: DANA 44 NEEDED
ALL THE NEW CORVETTES INCLUDING THE Z06 USE A DANA 44 CENTER SECTION WITH NO BREAKING ISSUES. A DANA 44 IS AS LIGHT AS A 12 BOLT, PLENTI OF PARTS,AND ACCEPTS MY 1LE BRAKES NO PROBLEM. I DO NOT WANT TO SMASH THE FLOOR OF MY TTA TO FIT A NINE INCH. THE DANA COULD HAVE BEEN A REPLACEMENT FOR THE NINE BOLT WHICH STILL KEEP THE CAR STOCK AND WORTH MORE, AND I WILL PUT THE 9 BOLT ON THE SIDE FOR THE REAL TTA PUREST.
I DID NOT WANT TO START A DEBATE ON THE DANA, OPINIONS ARE LIKE AS^%$#*S, EVERY ONE HAS ONE AND THERE ALL FILLED WITH YOU KNOW.
JUST LOOKING FOR A F BODY DANA 44 IN ANY SHAPE. THANKS
Car: 91 rs
Axle/Gears: 3.50 9"
Re: DANA 44 NEEDED
What do you mean smash the floor?
The corvette is also lighter and doesnt come from the factory with drag tires. They're efficient rears, lightweight, and cheap. Theres also no axle tubes to bend, so that I would imagine, would contribute to a little more strength.
I really dont understand why GM threw that decent rear under the vettes and not our cars. Why didnt camaros get the same reliablility? 10 bolts behind ls1's make me angry. Make more power than a c4...heavier too.
If you do find one, its gonna be priced high. I like your engine btw, always wanted to ride in a car with that engine.
If you launch your car at lower rpms, the 44 would probably last a while. But its definitely no insurance. I like to hammer down and know that NOTHING will break.
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: DANA 44 NEEDED
may i also suggest that you also put your request up in the "engine/drivetrain parts wanted" forum, it may yeild better results.
Car: 1989 TTA
Engine: 3.8 TURBO
Transmission: AUTO
Re: DANA 44 NEEDED
WITH THE 9 INCH AND TORQUE ARM THERE IS A CLEARANCE ISSUE SOMETIMES. YOU CAN EITHER NOTCH THE FLOOR, OR BEAT THE FLOOR WITH A HAMMER A LITTLE. EITHER WAY I DO NOT WANT TO DO THAT TO MY CAR. A LOT OF TTA GUYS RUN THE 9 BOLT WITH GOOD LUCK FOR A LONG TIME, BUT THE POSI IS THE WEAK LINK. I HAVE A FEW BUT I JUST WANT THE DANA 44. I CAN MAKE THEM STRONGER THAN I NEED FOR MY CAR. ITS AN AUTOMATIC. ONLY RUNS HIGH 11'S ON DRAG RADIALS
Car: 91 rs
Axle/Gears: 3.50 9"
Re: DANA 44 NEEDED
Didnt know that about the 9", I just picked one up. Thats actually a good thing for me, I need the torque arm up a bit to get away from the x-pipe.
I think its going to be near impossible for you to find the dana. Its been talked about and dreamed of a lot without resolve.
High 11s? So you really havent tapped much into that engine huh?
Car: 87 IROC L98
Re: DANA 44 NEEDED
I ran high 11's with a 383, a 3.27 9 bolt under the car and 26" tall slicks. I was also doing it at 117 MPH racing at around 5000' density altitude.
I then switched to a beefed up 10 bolt for better gear choices (not really worth the investment) and got into the low 11's before installing a 9" and a transmission with a transbrake at the same time which has now pushed my car into the mid 9's.
Car: 1989 TTA
Engine: 3.8 TURBO
Transmission: AUTO
Re: DANA 44 NEEDED
THATS A BONE STOCK ENGINE WITH BOLT ONS AND AN ALKY KIT. WHEN I SAVE UP SOME $$$$ I HAVE ANOTHER 109 BLOCK AND TTA HEADS TO GO CRAZY WITH. MY GOAL IS EVENTUALLY MID 10'S ON PUMP GAS WHICH ALOT OF GUYS WITH TURBO V6'S ARE DOING. ITS COOL TO DRIVE TO THE TRACK, BEAT UP ON SOME RACE CARS AND DRIVE HOME WITH THE A/C ON OR T TOPS OFF!!
Re: DANA 44 NEEDED
http://austin.craigslist.org/pts/600655420.html
A little spendy and it has 3.92 gears/spool, but it's a 3rd gen Dana 44. They're hard to find.
Car: 87 IROC L98
Re: DANA 44 NEEDED
Not much of a deal. A 9" which will have a better selection of aftermarket parts is cheaper. Hard to tell from the picture but it looks like it has the older cast iron calipers.
Here you go. An inexpensive, bolt in, 9"
http://cgi.ebay.com/ebaymotors/9-For...spagenameZWDVW
Car: 91 rs
Axle/Gears: 3.50 9"
Re: DANA 44 NEEDED
1500 bucks is ridiculous from a practical view. If youre one of those "keep it stock guys", then.......yea, good deal I guess.
Engine: 4++,350 & 305 CIs
Re: DANA 44 NEEDED
Did you know that the HP difference is so low that a street car will not know the difference? We're talking 10 HP at the most difference. Probably closer to 5 HP difference between a 9" and a 12 bolt. The Dana 60 does eat up a bit more HP than a 9". It's also a lot heavier than a 12 bolt or 9".
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: DANA 44 NEEDED
[quote=Batass;3686879]I dont see how thats a good deal. You dont get axles, just the housing. You can get the same thing from moser and its 600 bucks. And not as ugly.
Read that ad again. it does have axels. no center section
That would make a bolt-in setup for less than $1500
That beats the HELL out of ANYBODY else
Car: 91 rs
Axle/Gears: 3.50 9"
Re: DANA 44 NEEDED
Youre right, you know I've looked at that ad four times now. Each time I read something different. That is a good deal.
A little unclear about the housing ends for brakes, and what width is it? Third gen or fourth?
Youre really only paying 500 bucks for a stronger rear, all the extra stuff are things you'd be doing to your 10 bolt anyway.......or dana.
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Re: DANA 44 NEEDED
I recall sometime ago that the 9 bolt rears were presumably stronger than the dana 44. Try doing a seach on them and i believe that Miles from 9 bolt.com had the article for that. If I remember correctly, his email address was miles@koolmeister.com.
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: DANA 44 NEEDED
sailtexas186548
Jan 19, 2016 12:21 PM
