reinstalling tranny, not enough room
Old Apr 15, 2008 | 05:33 PM
rebel1222's Avatar
Car: Looking
Gentlemen,
I'm trying to reinstall the tranny after replacing the clutch on a my son's 2000 Camaro. I know it's not a third, but It is my sons car. The problem is there is not enough room between the body of the car and the engine to get the shaft of the tranny thru the hole of the splines of the pressure plate. We have tried jacking the front of the motor up to lower the back of the engine to no avail. Any suggestions or tricks?
Thanks for your help fellas, I really need it.
Old Apr 15, 2008 | 05:36 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Re: reinstalling tranny, not enough room
Try bolting the bellhousing on first, then bolting the tranny to the bellhousing.
Old Apr 15, 2008 | 06:07 PM
rebel1222's Avatar
Car: Looking
The tranny had a slave cylinder that we had to remove the bellhousing to install. There would be no way install the slave cylinder, if we were to bolt the bellhousing on first. Right?
Old Apr 15, 2008 | 06:34 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
T5? We can get to the two bolts that hold the slave cylinder onto the bell housing on my son's '91 RS, but maybe the 4th gens are different.
It is kind of hard to push back against the bellhousing to get the bolt started again but we've done it a couple times now.
Old Apr 15, 2008 | 07:46 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
if your sons car is an LS1 w/ a t56 then the front plate should be notched so that the bell can be put on first, then the tranny w/ slave cylinder.
Old Apr 15, 2008 | 08:27 PM
rebel1222's Avatar
Car: Looking
I will try this tomorrow and post the results.
Thanks for all the help.
Old Apr 16, 2008 | 05:30 PM
rebel1222's Avatar
Car: Looking
Well, the idea of installing the bell first won't work because theres no way to install the slave cylinder. The slave has to be bolted to the trans, and theres not enough room for it to clear the hole in the bell if not slid over the shaft, bolted to the trans , then the bell bolted on.
I can't think of another way except to somehow raise the body from the chassis. I know they have to do this job a thousand times a year on a 2000 camaro withe a v6 five speed. Mine can't be the only teenager to shred his first clutch.
It has to be easier than this GRRRHHH!
Old Apr 18, 2008 | 10:48 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
try removing the engine mount bolts for a bit more wiggle room
Old Apr 18, 2008 | 12:11 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
I have a 99 LS1 T56 car that I did a clutch install on myself. All I did was let the engine hang on it own weight and I didnt have a problem installing it with te bell houseing on. Here is the install manual I used.
http://www.installuniversity.com/ins...ch_install.htm
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Briandrex
Oct 5, 2015 06:20 AM
bjpotter
Oct 4, 2015 07:48 PM
Damon
Sep 26, 2015 04:29 PM
IROCZ1989
Sep 4, 2015 11:54 AM
