A little Tranny Problem
Old May 29, 2008 | 08:18 PM
Alex IROC Z-28's Avatar
Car: Camaro IROC Z-28 1987
Transmission: Automatic
Hi there...I have a 1987 IROC 305 TPI automatic.
I am swaping my 305TPI auto to a L98+auto from Corvette.
I have a mechanic on it but I want to be sure what is been done is the right thing and not been charge for extras that doesn't exist.....
My question is any changes need to be done?
I noticed that the vette's tranny have the speedometer eletronic and my camaro is analogic. The tail of the tranny has a slightletly diference.
According through the paper that I was give from the junkyard was a 1987 corvette so supose to be 700r4...but have some small differences with the original 700R4 from my camaro.
Anyone ever did something like that?
Any good tips or parts that I need to use or buy?
Thank's for all
Alex
Old May 29, 2008 | 08:41 PM
performabuilt's Avatar
Re: A little Tranny Problem
The corvette has a slightly shorter tail shaft and tail housing and the housing will not have provisions for your torque arm that will need to be switched. The shaft is only slightly shorter so you may get away with that. The dust cover will be different for the corvette also
Old May 29, 2008 | 08:46 PM
Can I change just the tail shaft so I can use the corvette tranny with all the original hardware?
Or I need to change all the hardware and leave the tranny alone?
Old May 29, 2008 | 09:21 PM
Changing he tail shaft would require a complete disassembly of the trans I think I would just change the hardware
Old May 29, 2008 | 09:24 PM
Where can I get the tork arm for this situation....?
Thanks for the help
Old May 30, 2008 | 05:48 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
as performabuilt said, leave the tail shaft alone. to take care of your torque arm problems, use the tail housing off of the one in your camaro.
Old May 31, 2008 | 01:48 AM
What about the eletronic speedometer sensor in the tranny?
Can attach a cable on the place of the sensor oq I have to use something else?
once again tks
Old May 31, 2008 | 08:00 AM
87zjeff's Avatar
once again tks
just swap the stuff over from your original unit.
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
