trans temp gauge
Old Jun 22, 2008 | 09:53 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
trans temp gauge
I want to install a trans temp gauge.Where is the best place to put the sensor in the pan.Who else has done this that might could offer up some info.I did a search but after about 8 pages of searching under trans temp sensor/gauge everything was about temp gauges and coolant temp sensors.Thanks
Old Jun 22, 2008 | 10:18 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
Re: trans temp gauge
i put mine on the return line from the oil cooler........
Old Jun 22, 2008 | 10:29 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i would put it in the line going to the cooler, that would be your highest temp, and closer to what the fluid in the tranny is
Old Jun 23, 2008 | 07:44 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Hmm,I didnt think about that.How did you mount the sensor in line?
Old Jun 23, 2008 | 08:01 PM
89RS_82Z's Avatar
i havent put one in but i think you can get a piece that has the male/female threds on it with a hole for the sensor
i would call Jegs and ask for tech support they are REAL helpful
BTW we are meeting up in MS this month and next if you can make it down
Old Jun 23, 2008 | 08:41 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Oh didnt recognize you.You changed your avatar didnt you.Where abouts in MS?
Old Jun 23, 2008 | 08:57 PM
89RS_82Z's Avatar
yea i did, sending a PM to you about the meet
Old Jun 23, 2008 | 11:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can get a "sensor manifold" to put the sensor in one of the cooler lines. I just have mine in the pan. It doesn't really matter all that much where you put it, the gauge is just going to let you know when the temperature isn't behaving properly.
Old Jun 24, 2008 | 05:23 PM
89RS_82Z's Avatar
thats the part im talking about, just easier in the line, you dont have to drill and tap the pan
Old Jun 24, 2008 | 07:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Theres not really enough meat in the pan to tap it, you need to use a weld nut to do it properly. If you put it in the pan, it also doubles as a convenient drain plug.
Old Jun 24, 2008 | 08:09 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
I think I`m just gonna use the sensor manifold.That sounds much easier.Plus I just had my trans built and it may mess up my warrenty if I go turning bolts on it.I had an extra pan and we welded a fitting on to it.We mad sure it would avoid the valve body and all the internals,but it was in the way of the shifter when the shop went to put it on.Thats all they were waiting on to be finished so I said screw it,deal with it latter.I wanna drive my car
Old Jun 24, 2008 | 08:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you lose your warranty just from pulling the pan, you need to find another transmission rebuilder.
Old Jun 24, 2008 | 08:22 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Not sure that I would.Better safe than sorry I`d check with them first.But I think I like the sensor manifold idea better.Sounds much easier and cleaner not having to drain the fluid and try to reuse it or buy more
Old Jun 24, 2008 | 09:22 PM
89RS_82Z's Avatar
tell me how it goes, thats how im going to hook mine up
hope to see you at a meet, maybe we can get one closer to you
Old Jun 29, 2008 | 08:38 AM
Pat Hall's Avatar
Seems like I've read that you can use the diagnostic pressure port that's located in the driver's side of the case above the shift linkage. I could be wrong though. It's a 1/8" NPT port with a pipe plug in it. Might want to look into that as well.
Old Jun 30, 2008 | 11:13 AM
88tpi350's Avatar
Car: 88 formula
Engine: 350 goin carb
look at your trans from the driverside, about where your shift selector is go about half way up there will be a small bolt about the diamater of your sender, pull it out. you will see that it looks just like your sender. put your sender there, that is where they belong. you will get the best reading from there on what your Transmission is actually doing not just the fluid temp.
colton_carlson
Mar 8, 2019 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
bamaboy0323
Aug 15, 2015 07:20 AM
