tci tourque converter lock up kit how to use
ok it's all installed and put in, with two switches just like the directions say to do
switch 1= tourque converter lock up only 4th gear
switch 2= tourque converter lock up 2nd 3rd and 4th
which set up do i want, idk anything about trannys
thanks yo
thanks yo
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: tci tourque converter lock up kit how to use
As long as it's locking up in 4th, and you don't mind how it feels to drive, then you're ok. If you've got a high stall on your converter, you might want something more sophisticated than that kit to make it feel right.
Engine: 383 Carb
Transmission: 4L60
What do you mean by "switch 1" and "switch 2"?
Engine: 383 Carb
Transmission: 4L60
Ok, use either switch you want then, as long as the converter is locked in 4th.
Engine: 383 Carb
Transmission: 4L60
The torque converter can't lock in 1st, regardless of anything you do with the wiring. Try it locking up in 2nd and up, and try it locking only in 4th to see with you prefer. You'll probably decide to lock it up only in 4th.
1992 Trans Am
May 10, 2023 07:19 PM
Eric-86sc
Aug 24, 2015 09:01 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
