6 speed in an 86 IROC?
I want to know how entailed of a process it is to install a T56 in my 86 IROC Z-28 to replace the t5. Any suggestions or places to look for instructions would be greatly apprecaited.
Pimpin' ain't easy.
Pimpin' ain't easy.
Car: Transformed 86 Coupe
Engine: 400 sbc
http://www.skulte.com/T56.html
There should be some info there, although I think it describes an auto to manual conversion.
I've done this swap, but my car originally had an Automatic.
The T-56 is almost a direct bolt-in replacement for the T-5. The only thing you have to modify is the crossmember, or you can buy one from Andris Skulte or Steve Spohn. Then replace your hydraulic clutch master/slave cylinder assembly with one from a T-56 (GM Part # 12559912). You also may have to cut the shifter hole back a few inches. That's about all there is to do and it will bolt right in.
-Good luck
89' Iroc-Z
ZZ3 short block-355 TPI ZZ9 cam
NOS 150 shot.
blah...blah...blah..
95' T-56, 6-speed
99' Z' rearend w/ 4.10's
The crazy fool racer of the UNfamous SW crew.
-Good luck
89' Iroc-Z
NOS 150 shot.
95' T-56, 6-speed
Car: 88 GTA
Engine: 350, 383
Transmission: T-56 & 700R4
http://member.aol.com/macewen001/T56.html
The article I wrote last year on the A4 to M6 conversion. Pretty thorough.
Skultes conversion is more related your setup since his was once a T-5 car.
Ryan MacEwen Pruyn
MacEwen Motorsports
1987 GTA 350 6spd, White OEM instruments, 17" Borbet Type A's, 275/40ZR17's, 255/45ZR17's, Koni Sport Adjustables, Eichbach Sport Springs, Poly U, everywhere, Guldstrand Engineering Panhard rod, LCA's
Ryan MacEwen Pruyn
MacEwen Motorsports
Nice article. Almost make it sound easy
86 Sports Coupe/red paint faded to pink with white lines from rubbing compound.
Next project - spray can investment.
LG4. T5 soon(maybe)....yeah thats it.
I did this swap 2 months ago. I bought the aftermarket borg warner t-56. This is a great set up for t-5 users because it uses the same clutch, bellhousing, hydrolic set up, and you dont have to cut up the floor. I paid a little over 2 grand, but it was well worth it, and was in the car by the end of the weekend
Car: 88 GTA
Engine: 350, 383
Well, there are two sides to that.
If you buy a T-56 used, it will usually come with all of the components, and it won't require shortening the driveshaft. Or was your aftermarket T-56 the sam overall length as the T-5 (not including bell housings)?
Ryan MacEwen Pruyn
MacEwen Motorsports
Ryan MacEwen Pruyn
MacEwen Motorsports
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
MacEwen, I am thinking about replacing my worn out 700r4 with a T56 (if I can find one cheap in a boneyard). After reading your article, my only question is where would I obtain a adjustable buffer for the speedometer calibration? Thanks for any input.
Scott
88 GTA L98
14.389 @ 95.2 mph, 2.001 60'
In search of the elusive 1.9 60 foot time.
Scott
88 GTA L98
Car: 88 GTA
Engine: 350, 383
Jegs and/or Summit carries a Cyberdyne unit. They are around $75.
Ryan MacEwen Pruyn
MacEwen Motorsports
Ryan MacEwen Pruyn
MacEwen Motorsports
mustangman65_79
Aug 11, 2015 03:17 PM
