Borg Warner??
Old Sep 21, 2000 | 10:55 PM
CanadianBeast's Avatar
Borg Warner??
Ive got an 89 iroc-z with 350 tpi, 700-R4, and the borg warner rear end that had original 2.77 gears. The guy I bought it from said it had 3.42's now. Is that possible since its such an obscure rear end. Isn't it more likely the 3.45's that came with some camaros. Also has anyone made this swap and knows what speedometer gears to use to correct the speedo.
Old Sep 22, 2000 | 02:21 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Count the bolts on the differential cover, to see if maybe the guy swapped it with a 10-bolt. If it has 9 bolts, its a 9-bolt, and 10 bolts, its a 10-bolt rear end. Easy huh?
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
6speedIROC
16
Mar 15, 2023 08:33 PM
PurelyPMD
May 5, 2016 04:57 PM
Vojtush31
Oct 11, 2015 01:07 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
scottmoyer
Sep 7, 2015 07:06 PM
