Any advise on modifying the govener to up shift points???
Old Sep 11, 2000 | 06:03 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Need to get about 200-300 more rpms out of first gear,wondering if anyone has done these types of mods before and can give me some tips.
Steve
TTA#850,bone stock,best 13.68@100
TTA#861,near stock,best 12.15@112.95(11's soon to come)
89 GTA,nowhere near stock,soon to be low 10's
Old Sep 11, 2000 | 06:06 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
One more thing,I have the TH-200R4.
Thanks,
Steve
TTA#861,near stock,best 11.99@112.26
89 GTA,nowhere near stock,longing for 10.0
Old Sep 12, 2000 | 02:20 PM
89ProchargedROC's Avatar
Yeah, sont do it. At my shop we dont even bother playing with the governor springs. It is a pita. Something always goes wrong, i reccomend shifting yourself.
Old Sep 12, 2000 | 02:28 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
I wish it was that easy
I have a Stageright transbrake installed,the way it works is when you put it in 1 the brake is turned on and I can build boost,when you click it in 2 it goes(and sometimes lifts the left front wheel an inch )but it shifts at like 4500 and I manually shift to third at 5200.
I swapped the govener with my freind Ed's which was suppesed to shift at 5200 but it shifts at 5000 so I'm looking for the extra 200 rpms.It might not sound like much but it will help alot in keeping the motor in it's overall powerband.
Thanks,
Steve
Old Sep 12, 2000 | 04:10 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Is there a TV cable on those you can adjust?
Old Sep 12, 2000 | 07:01 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Yes it does and it is adjusted and working properly.I know for sure it should shift 1-2 at 5200-5300 from talking to other TTA owners.I was thinking maybe the shift kit in the trans may have altered line pressure down so as to reduce my shift points.What do you think?
Thanks,
Steve
Old Sep 12, 2000 | 08:37 PM
Well, then your best bet is to call fairbanks and get an adjustable governor kit. They come with i think four different springs that you can play with. If you need the part number, i am going to work tomorrow and can give you a price at your cost.
later
Old Sep 12, 2000 | 10:12 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
B&M sells a governor speed shift kit. The price is around 30 dollars. The kit contains springs and weights that can alter both the 1-2 and 2-3 shift rpm. You will have to experiment with the combinations until you get it correct. I am using this kit in my GTA and it took three tries before I had it perfect.
Old Sep 13, 2000 | 06:11 AM
Pro Built Automatics's Avatar
You said you changed the governor, which one did you change it to? There are three governors available, if you want to get the extra 2-300 rpm out of it, you can grind off a little of the small weight. Compare the two governors you have been using, look at the small weights and see the difference in size. Continue to modify the small weight in the same direction (lighter), remove a little at a time & this will do the trick. Most people who want the exact rpm WOT shifts have to do this, it will take some work.
Glad Too Help!!!
Old Sep 13, 2000 | 06:19 AM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Thanks Pro Built,the govener I was using was from a freind who had modified it by taking some material off the lighter weight,only I have to duplicate it on mine scince I have to give his back and then take a little more off mine and try it.
Another question,the trans seems to,at certain times,stay in second gear after I stop and try to leave from a light or whatever.Why would it stay in second and not drop back to first.
Someone suggested the Intermediate Servo may have a broken spring,which could be causing all my problems but I don't know how true that is.
Thanks again,
Steve
[This message has been edited by TTA850 (edited September 13, 2000).]
Old Sep 13, 2000 | 06:23 AM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
One more thing,man is it a pain to keep dropping the pan to remove the governer(I spelled it right this time )
Steve
Old Sep 14, 2000 | 07:06 AM
-=Nitro7=-'s Avatar
You shouldn't have to drop the pan to remove the governor. I am assuming the 200 is like the 700 and TH350 that the governor is located towards the back under the Dust Cover looking thing. At most you should only have to drop the tranny down by undoing the crossmember.
86 Camaro SC, 310, Edlebrock Intake and Carb, Flowtec Headers, Ported polished heads and intake. TH350 tranny, Jacobs Electronics Ignition.
Old Sep 14, 2000 | 01:56 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
I wish it was that easy,if you ever get the chance to look at a 200R4 trans pan,there is a big section like all trans have and a little section towards the rear(the governer is in there )
Steve
Old Sep 14, 2000 | 05:11 PM
-=Nitro7=-'s Avatar
EEKK!! My bad I never really have messed with one. I feel for you..
Old Sep 24, 2000 | 03:41 AM
The 2004R is more sensitive to TV cable adjustment at an idle, too much & you will start in 2nd gear. If you do this and it works, but later throttle openings start to soften the shifts then you will need to redo the geometry at the carb/injection linkage. If you have more questions give me a call at 800 7763288 Mon-Sat 10-6 PST.
Glad Too Help!!!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
