Lound CLUNK.....Probly not the best noise
Car: 1986 Trans am-Firebird
Transmission: Stock
I have and 86 firebird trans am and when it is at a complete dead stop and you get on it the front end of the car lifts up and there is a loud CLUNK! i have replaced the Read shocks and i was wondering could this be the front shocks? If not what else could it be. But i have also checked the u joints and they are fine and there are no trany mounts. Any ideas would help thanks
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
1 Post
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
Re: Lound CLUNK.....Probly not the best noise
No tranny mount!!! then that clunk is the tranny hitting the trans tunnel. I've had this happen to me a few times.
Transmission: Stock
would that be the thing behind the tranny pan that holds up the tranny
Last edited by 19transamtpi86; 07-10-2008 at 09:23 PM. Reason: Automerged Doublepost
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Look between the transmission and the crossmember then. That's where your tranny mount is. You'll probably find that if you lift up on the tailshaft of the transmission, you'll see the tranny mount is broken.
Transmission: Stock
Transmission: Stock
Car: 1990 Pontiac Firebird
Engine: 305 5.0 TBI
Axle/Gears: 2.73 Open Diff.
this happened to me a few weeks back. just check between the tranny and the cross member like he said. the mount is probably broken. it cost about $6 at the parts store and its very simple to replace.
Transmission: Stock
Well boys you were all right it was the tranny mount thanks for the help
Transmission: Stock
Well i replaced the mount pain in the **** to do by yourself and not having a lift and having to use a jack and jack stands, but it noise continues which i hope it doesnt, what should i look for next?
Transmission: Stock
clunks gone guys thanks for the help
sjorgens
10-01-2015 07:54 PM
