700R4 Problem
Old Nov 7, 2000 | 02:28 PM
Chrome's Avatar
Car: 92' RS Camaro
700R4 Problem
Hey, Got a question about the 700r4 that i have. I got it out of a junkyard and put it behind a built 350 in my 85camaro. It seems to be completely unpredictable. When I put it in reverse, It engages hard, and it'll go right away. When I put it in drive, it pauses before it engages and when it does it's not near the force as the reverse. Then it upshifts erractically. Sometimes it'll go to 4000 and almost too high, i have to get off the throttle for it too shift, and other times it'll shift at 2500rpm at WOT, and that sucks. I was reading another post and i have had the little greenthing on the TV cable not at the end of the wire, could a sticking TV cable be the cause of this. I have a B&M shift kit out in the garage that I haven't installed yet, would this help???
Old Nov 7, 2000 | 03:27 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Was this the message you were reading?
https://www.thirdgen.org/messgboard/...ML/000454.html
Sounds like yeah, that's a sticking TV cable. The cable could either be worn out internally, or the linkage inside the trans is worn out. You could replace the cable, and if the new one sticks, go after the linkage. The TV linkage isn't that bad to get at; you'd just have to drop the pan down. It's "next to" the valve body, on the passenger side, and should be held in with 3 bolts, if I remember correctly.
Search down a bit for the "changing the TV cable" message... good luck, & let us know how it goes!
--Oh, the shift kit won't help the TV get unstuck. You do have do drop the valvebody to install the kit, it's possible that by removing the valvebody (which requires you to remove the TV linkage), that you'd unstick the TV. But if that doesn't happen, you're just adding another "unknown" to the problem.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 7, 2000 | 07:45 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Not to sound like a jerk, but the fact that is came from a junkyard is part of the problem. A) you don't know what the bozo before you did to the tranny B) most junkyards don't give a crap what happens to the tranny, as long as there is a demand for them. It probably got dropped, kicked around in the dirt, full of water, and who knows what else.
If it were my car, I would make sure the TV cable is OK, if in doubt, replace it. Then I would take a good look at the governer. If the tranny sat out for awhile, the governer may have become rusted up and it may be sticking. I would pull it out and carefully inspect. If in doubt, replace it.
If that doesn't fix it, I would drop the valvebody for analysis.
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
Old Nov 8, 2000 | 04:02 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
replace the TV cable first. i'm not kidding. these things cause a lot of problems because they all look good from the outside. but the problem is on the inside.
Old Nov 8, 2000 | 11:32 AM
Tigger84TA89BIRD's Avatar
I recently installed one of the B & M kits in a 700R4 and learned the HARD way that there is one thing they forgot to mention. there is a fluid pressure drain-back hole in the front pump that is only 1/8". with the increased pressure created w/ the kit, you need to increase the hole size to 1/4" or you will blow front main seals (pulled tranny 5 times before I figured this one out)
good luck!!!
Old Nov 9, 2000 | 01:54 PM
Chrome's Avatar
Car: 92' RS Camaro
Thanks guys. I'm gonna invest in a new TV cable and see where that gets me. I'm 99% sure thats the problem because I can't even adjust it, the ratcheting mechanism does nothing when I try to adjust it... Is that true about the B&M kits??? Will enlarging that hole hurt anything??? Thanks...
Old Nov 9, 2000 | 01:56 PM
Chrome's Avatar
Car: 92' RS Camaro
Oh, and GM...
I trust this junkyard and I feel relatively safe when I watch them remove it from the vehicle. A 1987-88 Astro van in this case. And when I pulled the pan the fluid looked good.
Old Nov 10, 2000 | 03:31 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Tigger, 1/4" is huge! Are you sure about that? I've had the B&M Shift Improver kit in my trans since 1997, and haven't blown a front seal yet.
Chrome, the trans could've been majorly abused by that AstroVan driver..
Old Nov 11, 2000 | 02:51 PM
Chrome's Avatar
Car: 92' RS Camaro
Yeah, I was considering taking it back and swapping it for another one. They said they'd do that if it was in bad shape. I'll have to see how it's like when I replace the TV cable. Thats the only bad part about getting one at a junkyard, you don't know how hard the previous owner was on the tranny...
1985 Camaro
74' 355 Small-Block
Doublehump Heads
Holley 750DP 4160
Edelbrock Performer
BlueRacer Cam 232/232
Keith Black Pistons
700R4 w/ B&M Shift Kit
B&M Megashifter
Old Nov 11, 2000 | 04:05 PM
Chrome's Avatar
Car: 92' RS Camaro
I got a question. How much and where can I get a corvette servo??? How hard is it to install one of those??? Haven't done that before... Thanks...
1985 Camaro
74' 355 Small-Block
Doublehump Heads
Holley 750DP 4160
Edelbrock Performer
Keith Black Pistons
B&M Megashifter
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
