where is the VSS
Old Nov 14, 2000 | 07:12 PM
Blue Thunder's Avatar
where is the VSS
I know what the VSS is but I don't know where it is located. I also don't know what gears have to be changed (driven gear, Speedo gear) nor where they are located. I think they might be in the tail shaft of the tranny but I'm not sure. Has anyone went from 2.73's to 3.73's and had this same problem? If so what was done to fix it? I've heard alot of different things but I'm not sure what to do. I what to eliminate the VSS and still have the speedometer reading as close as possible.
Old Nov 14, 2000 | 08:13 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Read the responses to your previous question. NMany of the questions you are asking is a repetion of your previous question and they have been virtually all answered.
As for HOW to get at the gear, I suggest purchasing a shop manual. It is worth its wait in gold and will show how to disassmble and reassemble far better (and with pictures often).
As for the gears needed, I stated the Driven and drive gears that you needed in your previous question. Go to any GM dealer and specify what I answered in your previous thread. They will know which gears to get.
[This message has been edited by Glenn91L98GTA (edited November 14, 2000).]
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
