Need help identifying transmission
Old Aug 22, 2008 | 08:22 PM
gerard's Avatar
Car: 84 trans am
I got a transmission to replace my t5. I think it came out of a '94 V6. I've read that some '90s V6 T5s have weaker transmissions and I just want to know if I'm wasting my time putting it into my '84. I can't find any info on it. Here are the numbers off the case as the tag is illegible:
Gear Housing Numbers: 13-52-065-922
Tail Shaft Housing Numbers: 13-52-066-936
Thanks for any help you can give me.
Old Aug 26, 2008 | 05:44 PM
dyed's Avatar
Car: 84 Z/28
Transmission: 700R4 - rebuilt by me
Axle/Gears: 3.73 posi
Re: Need help identifying transmission
Was your original tranny behind a v8? If so, it will be better to rebuild it than to put in the v6 tranny, regardless of the WC designation. All v6 trannys are only rated up to about 170 horses. Your profile says you've got a 350 in there, and the weakest 350s should be topping out well above what your tranny will take. I've done it with an original v8 tranny and still shot the thing on a tired old motor. If you really wanna know, Tony down at Astro Performance is THE t5 guy, even according to Tremec.
Old Aug 26, 2008 | 05:57 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The V6 isn't going to fit a V8 (different spline count) without some tinkering and then it'll be weak even behind a 305, much less a 350.
JamesC
Old Jan 27, 2009 | 02:40 AM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
Hi,
13-52-066-936 R3
is the same number I have on my Tail Shaft Housing. Mine is out of a 90´305.
Can somebody tell me if this is a Worldclass and which gears it has?
Thanks Rob
Old Jan 27, 2009 | 07:04 AM
JamesC's Avatar
Originally Posted by Rock-Bert
13-52-066-936 R3 is the same number I have on my Tail Shaft Housing. Mine is out of a 90´305. Can somebody tell me if this is a Worldclass and which gears it has?
The T5 sticky at the top of the page doesn't list 1352066--that I saw. If the trans is truly from a 90 V8, it would be a WC.
JamesC
Old Jan 27, 2009 | 09:05 AM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
Hello James,
I know, didn´t find anything about this number.
It´s truly a 90´ thats everywhere on the tranny marked.
BTW, can you tell me where the hole is to look up the drive gear color???
Very Important!!!
Old Jan 27, 2009 | 09:10 AM
JamesC's Avatar
Tail shaft. Remove the VSS or cable and sleeve. That'll show you the driven gear and if you look into the 'hole,' you'll see the drive gear.
JamesC
Old Jan 27, 2009 | 09:50 AM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
Thanks a lot!
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Linson
Sep 21, 2015 01:08 PM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
