What tool to fill rear oil?
Old Aug 22, 2008 | 10:30 PM
xChAoSx's Avatar
Car: 1987 Firebird
LKJKJLKJLKJLKJKLJL
Old Aug 22, 2008 | 10:36 PM
blackblazer717's Avatar
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
Re: What tool to fill rear oil?
im assuming its a 10 bolt..... there should be a plug on the pass side of the differential, remove that to ut the gear oil in,
if its a 9 bolt the fill is on the cover.
to make it stop leaking remove the cover bolts and cover, clean both mating surfaces (cover and diff) than eather use strait RTV or a dff cover gasket. than re-assemble wait a little while for rtv to set than fill with 80W-90..... 3.5 pts......
Luke
Old Aug 22, 2008 | 10:49 PM
xChAoSx's Avatar
Car: 1987 Firebird
ASDASDASDASDASD
Old Aug 22, 2008 | 10:53 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
The gear lube bottle should have a nipple thingy on the end. If you can't fit it in the fill hole, slide a piece of 3/8" hose over it and run it into the fill hole to the rear.
Old Aug 23, 2008 | 06:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There's also a bottle pump (sold at most auto supply stores) which is cheap and works pretty well.
JamesC
Old Aug 23, 2008 | 03:21 PM
xChAoSx's Avatar
Car: 1987 Firebird
ASDASDASDASDASD
Old Aug 23, 2008 | 03:25 PM
Lo-tec's Avatar
80W-90 or 85W-90 gear oil, regular not synthetic.
Edit:
If you jack up the rear of the car, put jack stands under the rear frame rails in front of the lower control arms, and then let the rear axle hang down (remove jack), it is really close to being level. You should be able to pour the fluid in with just the nipple on the end of the bottle. Should take 2-3 quart bottles. Stop filling when it starts to run out of the hole.
Old Aug 23, 2008 | 03:32 PM
xChAoSx's Avatar
Car: 1987 Firebird
ASDASDASDASDASDASDASDASDADA
Old Aug 23, 2008 | 03:42 PM
JamesC's Avatar
Many members on the board, to include me, use Mobil 1 75-90 synthetic (with a bottle of GM additive if you're running a limited slip).
JamesC
Old Aug 23, 2008 | 03:51 PM
xChAoSx's Avatar
Car: 1987 Firebird
would 85w-140 gear oil work? I think that is the only gear oil that autozone carries.
Old Aug 23, 2008 | 04:00 PM
Lo-tec's Avatar
No, it should be either 80 or 85 W90. They have it, ask someone that works there.
Old Aug 23, 2008 | 04:31 PM
xChAoSx's Avatar
Car: 1987 Firebird
will do thank you guys. I can always count on the integrity of this forum.
Old Aug 29, 2008 | 09:04 PM
87IROC92RS's Avatar
Car: 87 IROC
Transmission: built 700R4
Axle/Gears: 3:27 posi
I run 80-90W Lucas Synthetic oil and Posi additive, however my way of adding the fluid is a little diffrent.. I take a bottle of motor oil, cut it in half, clean it out then screw on the nipple from a gear oil bottle and attach a 3/8 clear hose then raise the bottle above the diff and pour in from the top ( usually only takes about 5 minutes to add the 3.5 pints )
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
