Flywheel question
Old Jan 8, 2001 | 12:55 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
Flywheel question
I have two flywheels for manual transmissions. They are both Gm and 153 tooth. One is for a 2 piece seal and the other is for a 1 piece seal. But the one that is for the one piece seal is like a good quarter inch thicker when they are both laying flat. Will it still work and why are they different thickness?? Thanks Kevin
Old Jan 8, 2001 | 03:15 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
Anyone?
Old Jan 8, 2001 | 08:13 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
ttt
Old Jan 8, 2001 | 10:44 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
PLEASE!!!!!!!
Old Jan 8, 2001 | 10:46 PM
Bort62's Avatar
Hm, it is My understanding that the Differance between the TWo Flywheels (1 peice and 2 peice rear main ) is the 163 and 153 teeth differance, But I could very well be wrong.
Other than that, No idea (
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Livin' the Stereotype
Old Jan 8, 2001 | 10:58 PM
jrob350's Avatar
The 2 piece rear seal flywheel is for use on 1985 and prior blocks because they are internally balanced. For 1986 and newer engines the thicker flywheel is needed because they are externally balanced and need the extra wieght.
Old Jan 9, 2001 | 11:11 AM
kjgroen's Avatar
Car: Trans Am
Engine: L69
Well it is the flywheel for the one piece seal that is thicker. I just wanted to know if it will work. Does the thickness matter. I think it may have came off of a 283? But I am not sure. Thanks Kevin
Old Jan 9, 2001 | 12:26 PM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
You'll find the bolt pattern for the 1 pc rear seal flywheel/crank is smaller than that of the 2 pc rear seal crank/flywheels.
Old Jan 9, 2001 | 12:28 PM
FastBroker's Avatar
Yeah, I don't believe that they will even bolt-up... Cannot swap anyway because of balance issues...
Old Jan 9, 2001 | 01:46 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
But i should be able to use the thicker flywheel on my 84 motor then. Regarless of thickness. I dont need the flywheel for the 2 piece seal. It just happens that i have both and am wandering why the one for the one piece seal is alot thicker??
Old Jan 9, 2001 | 04:05 PM
KevinP92Z's Avatar
No, you cannot use the one piece seal if you are building an 84 motor. Blocks prior to approx 86-88 year models were two piece rear seals. The bolt circle pattern on the crank and flywheel of the one piece seal design is smaller in diamter than the 2 piece crank's bolt circle. They won't interchange or bolt up. Thanks to wonderful GM, the 87-88 was suppossed to be the year change-over to the one piece rear seal design, but some earlier 86-87 blocks got it, some 88 blocks didn't, so watch the change-over year models.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
Old Jan 9, 2001 | 07:29 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
God am I stupid! I ment to say can i use to flywheel for the 2 piece seal on the 84 crank!! It is 153 teeth and the only thing i see different from the other one is that it is thicker. Sorry for all this confusion..... Kevin
Old Jan 10, 2001 | 02:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The crank flange is different in several ways.
It is sufficient to say that if you bolt a one-piece flywheel onto a one-piece crank, the clutch surface comes out in the same plane as a 2-piece assembly. They are totally interchangeable as an assembly regardless of the thickness of the individual parts.
Old Jan 15, 2001 | 11:05 AM
kjgroen's Avatar
Car: Trans Am
Engine: L69
OK That is what I wanted to hear! Thanks Kevin
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Trickskier
Aug 29, 2015 01:12 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
