700r4 no reverse little drive
Old Oct 5, 2008 | 06:47 PM
turbotransam83's Avatar
Car: 1991 GTA
Axle/Gears: Its posi.... :)
Ok First off its not in a 3rd gen but its Still 700r4. I have a 88 K1500 305 v8 700r4 4x4. Just Did a motor swap took motor from my 1988 firebird 305 and put it into my k1500 because im building a 350 for my firebird. Engine runs great transmission is full transfer case works perfect. Cannot get the truck in reverse and when i get it in drive it seems like it slips in and out of drive while it slowly accelerates. i can floor it nothing, i can lightly start off and it moves somewhat. When i get moving it will shift into 2nd gear but i cant get over 20 mph. Transmission is full with clean new fluid all lines are hooked up no leaks. i tried the adjusting the T.V cable and that seems to have no effect on it. any suggestions will be helpful.
Old Oct 5, 2008 | 06:49 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Re: 700r4 no reverse little drive
I have a similar problem, but I just put in a shift kit. The book told me that the pressure regulator valve c clip could not be seated properly, or it's incorrectly put together, but another problem would be interesting to see..
Old Oct 5, 2008 | 10:03 PM
drfrankenstein's Avatar
dude iv got the same issue, except my trans dosnt appear to want to shift into second, it just drives as long as i dont hit the gas, hittin the gas does nothing dosnt appear to be slipping but it also isnt really doing anything, i mean i have drive but thats it.
Old Oct 6, 2008 | 04:10 PM
Car: 1991 GTA
Ok got a chance today to check and see what the problem could be. i started off by checking fluid - full. then checked linkages - ok. looked for any leaks or lose wires - none. So i dropped to the pan off the transmission and what do i find or should i said dont find..... No transmission filter!!!! the guy who rebuilt it forgot to put one in before he put the pan on. Partly my fault for not checking before i put the new motor in but hey i figured its a professional shop they should know what they are doing WRONG!!! Anyways i put a filter on and filled up the transmission and low and behold it works fine. Wasn`t working before because it had no way of getting the fuild lol. oh well goes to show everyone can make mistakes i guess.
Old Oct 6, 2008 | 07:15 PM
Kevman's Avatar
Engine: 2004 LQ4
Mine was the Pressure Relief valve or something, had a spring, 2 pistons and a long rod. Put it back in with the c clip, and boom, reverse, no slipping, and it shifts like a crazy bugger.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
BewleyBizzIROC
Aug 14, 2015 02:52 AM
hokis
Aug 9, 2015 03:57 PM
