how to make 700 shift past 4k at wot
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
my motor peaks at 4k and it shifts rite at that in OD...is there any way to make it shift a lil later like 4500/4700 its an 89 700 r4
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: how to make 700 shift past 4k at wot
Should from the factory unless you have changed the rear gearing.
But anyways, you can get a Governor kit from B&M, TCI or Superior. The springs and weights on the governor directly effect the shift points. There is a combination of colored springs and numbered weights to use. Its not really hard, just requires a day of test and tune. The governor can be removed with the tranny in the car. The instructions give you a listing of the driection to go in and it will probably take a few tries. But it worked out nicely for me.
Problem is most Lo-Rev boost valves dont hold enough line pressure to keep it in 1st. Most stock autos will shift up anyways if you have the shifter in Low 1.
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
An '89 700R4 shouldn't shift at 4k. My old '89 Firebird A4/LB9 car shifted right at 5k every time. Adjust the TV cable...that's why it shifts too early. Don't ask me how to do that...I've never had to. But that sounds like the problem
Car: check
Engine: check
Transmission: check
I used a Pro-Built custom Trans-Go reprogramming/shift-kit setup and am very happy with the results. At the same time I added the b-body fix kit valve to be able to hold 4th at WOT.
RBob.
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
So true, this is a built-in GM anti-abuse item. Best bet to cure this is a Trans-Go reprogramming kit. They hi-jack the 4-3 setup valve and turn it into a 1-2 manual shift valve. It works.
RBob.
RBob.
There are a few companies that sell this part.
There is a downshift anytime more than I think its 1/2 oe 3/4 throttle is seen. So its almost impossible to cruise in 4th at high speeds unless the tranny downshifts. See Superior, B&M or TCI for the part. Called a Upshift sleeve or something like that. Dana at ProBuilt may also sell it.
I think that is what RBob was speaking of.
GM part # 8673948. Called a b-body repair kit. Allows full throttle in 4th without the trans shifting back into 3rd. My understanding is that it applies to mid 87 and newer valve bodies. I have direct experience with it used in late 80's/90-91 transmissions.
went onto gmpartsdirect and they show no results for that part number. anyone have a link to this part?
Car: check
Engine: check
Transmission: check
I'm thinking that this part has been discontinued. Which would explain why the part number doesn't show up.
There is another method of obtaining WOT 4th. It involves modifying the TV sleeve. Here is a link that shows how to do it:
http://www.joby.se/corvette/mods/2002-0X02_tranny_wot/
There are aftermarket sleeves to do this but the ones sold usually just increase the amount of throttle before the 4-3 down shift occurs. They still don't hold 4th at WOT. Which is really bad as the 4-3 shift can easily over-rev the engine.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
That link takes me to a search screen. Put in the b-body fix part # and nothing???
RBob.
RBob.
if you put "8673948" into the search block and hit search it comes up with this---
Legend: Alternate Part Substitute Part Information Show All | Show prefered Line Code
Parts
8673948
Line code Part Number List Price Your Price You Save In Stock Quantity Buy
D37 8673948 Part Description
list price your price you save in stock
$19.72 $13.62 $6.10 No
Buy All Selected
Parts
8673948
Buy All Selected
Car: check
Engine: check
Transmission: check
That is most likely the b-body fix kit. Price is in the right area. Note that they don't have any in stock. Their search engine probably needs to set cookies on the searchee's PC. Which I have set up to not allow.
RBob.
RBob.
someone972
Aug 30, 2015 12:52 AM
