can a 4l60e electronic speed sensor be converted to a cable type speed sensor???
alloy
close
Try this link. About 1/3 of the way down. Looks like there is one kit for 93 to 97 700R4/4L60E's, and another one for 98 to 04's. But it's not cheap at all.
http://www.transmissioncenter.net/sp...#Misc.%20Gears
thanks for the link. your right its not cheap. any other ideas to get my speedometer working?the 4l60e is in an 89 camaro that originaly had a 700r4 with a cable driven speedometer. is there a stock style electronic speedometer that would work?
alloy
close
Only other thing I know of is the Cable-X box. Look further down on the same page I linked to. But again, not cheap and it's an electronic gizmo instead of a mechanical connection..
It's the same problem with T56's. That's why I figured out how to mod mine for a cable drive.
how were you able to make it work??
alloy
close
I machine the tail housing and make a special sleeve for the conversion. It's only for the T56's.
i have access to a machine shop so that is a possibility for me. if i could see a picture or get a few details that would be great. what would i have to do about the output shaft a drive gears for the speedo cable.
alloy
close
This is only for a T56, won't work with a 700R4/4L60E.
well thanks anyway.
Tags 4l60e, adapter, cable, conversion, converting, convertions, electronic, module, problems, sensor, speed, speedometer, speedsensor, trans, transmission
