How does a shift kit work?
Old Feb 20, 2001 | 06:28 PM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
??? I was considering putting in a 6-speed this summer basically to be a little different and have a little fun with the standard, but I know that an auto will save some time in a race. So what's the deal between the 6 and the auto with a shift kit? Opinions please.
Take 'er easy, and if
she's easy, take 'er twice!!!
Old Feb 21, 2001 | 12:02 AM
Hummer's Avatar
Car: 1986 Z28
Old Feb 21, 2001 | 01:51 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Shift kits come in three basic forms.
1. Firmer shifts, and manual control over the shift points. First of all, you can have manual shifts in a stock tranny, but the shift kit alows more fluid to pass though the seperator plate. Second, this kit really shouldn't cost anything. It's one of those mods that you can do without buying anything. But if you don't know what you are doing, go ahead and buy.
2. Even firmer shifts. Basically letting more pressure pass through the seperator plate. And also, new check ***** and different rate springs for the govener, which makes the shift points later or earlier.
3. Full race. Full manual controls over the shifting. With the others, you can still put the car in third,(drive) and go from stop to fifty, and the tranny will shift automatically. Or if you leave it in second, it will start out in first, then shift into second automatically. But with the full race, every time you come to a stop, you have to down shift. Basically a manual tranny, but with no clutch.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Feb 21, 2001 | 02:19 AM
Hummer's Avatar
Car: 1986 Z28
Thanks for the info. Open queestion for everyone.....What would you do?
Old Feb 21, 2001 | 10:25 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Get a 6 speed! Closeer ratios keep your power right where you want it, plus it is unique and FUN!!!!!
Old Feb 22, 2001 | 02:20 PM
stingerssx's Avatar
With out a doubt, get a manual. Wether it be a four, five, or six speed. But if you got the dough, get the six.
Old Feb 22, 2001 | 03:15 PM
Killer-Z's Avatar
6-speeds are too much shifting go for a 5 or 4.
Old Feb 22, 2001 | 03:23 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
yea it is a lot of shifting but since the ratios are so close you can shift from 3-5 or 4-6 or whatever. Just use them all when you race
Old Feb 23, 2001 | 05:54 PM
Hummer's Avatar
Car: 1986 Z28
DAMN!!!! You guys twisted my rubber arm. I had almost completely decided to save some cash and stick with my auto, but I see I now have no choice. I think I've got a buyer for my tranny already, although I'm not sure what to charge him for it. Any guesses on how much I'll end up spending on this project?
Old Feb 26, 2001 | 05:39 AM
stingerssx's Avatar
The only difference with 6 speeds compared to 5 speeds, (as far as shifting goes) is the 6th gear is more of an over drive. In both 5 and 6 speeds, the fourth gear is 1:1 and the fifth speed is an overdrive. The sixth gear, is more of an overdrive. Where 5 is .75:1, 6 is .63:1.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
drathaar907
Aug 6, 2015 04:20 PM
