Will Lockup700r4 work without tpi setup?
Old Mar 4, 2001 | 09:00 PM
T-Tops's Avatar
Will my lock up on my 700r4 still work without the tpi setup on the engine. Going
carbureted on engine but the computer will still be in the car???
Old Mar 4, 2001 | 11:34 PM
Birmass's Avatar
No, you'll have to get a kit from someplace to lock up the convertor. I think it's a B&M type kit. Search the board and you'll find plenty of references to it.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
All your base are belong to us.
Old Mar 5, 2001 | 08:19 AM
82camaro's Avatar
Car: 82 camaro SC
Without the TPI hooked to you computer, your SES light will be on and the computer will be in "limp home" mode and not lock the converter. B&M, TCI, Painless wiring, etc... make kits to lock-up the converter. Or you can make a manual switch. Or both.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Mar 5, 2001 | 04:36 PM
The ODB's Avatar
the converter locks when you supply 12-volts to the purple/black wire going into the transmission.
Old Mar 5, 2001 | 04:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<font face="Verdana, Arial" size="2">Originally posted by The ODB:
</font>
Maybe on the early 700's with the Type 1 lockup harness inside. On later ones the converter locks when the tan and black wire is grounded. +12v is always present on the purple wire except when the brake pedal is depressed.
Old Mar 5, 2001 | 06:16 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
i have an 83 camaro that had cross fire injection and a 700R-4. when i removed the tranny i don't remember there being any wires to the tranny does this mean it was disconnected by previous owner or my car didn't have it?
LONG LIVE THE MUSCLE CAR!!!!! MAY ITS REIGN NEVER END
1983Z28 350w/ edelbrock performer RPM power package with 64cc aluminum heads, dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, B&M shifter, dakota digital gauge package, procharger supercharger.
Old Mar 5, 2001 | 08:22 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Some early models had lockup built in. You can drop your pan and wire the 4th gear pressure sender to one side of the lockup valve, then wire the other side to the case. Then all you need to do is apply +12v on this wire (IGN fused) and it will always lock up in 4th which is usually not a problem behind a v8. Just check your lockup solnoid and make sure it is a two terminal type. Early ones are 1 terminal. They are interchangable though and could easily be changed without dropping more than the pan and filter.
Check this link:
http://www.purplesagetradingpost.com...o/700R4p2.html
It has many ideas on locking up without a kit. Hope it helps.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Aug 13, 2015 08:28 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
squiggy2
Aug 9, 2015 09:30 PM
