Will a bad pilot bearing cause clutch chatter?
Old 03-04-2001, 09:04 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
I changed my clutch last summer. I had clutch chatter with the old clutch and after a week or two with the new clutch it started to chatter also. I had the flywheel resurfaced but I did not put in a new pilot bushing, unless the machine shop did it but I doubt it. Could this cause vibration or clutch chatter? Or could it be a result of high rpm usage? Could this cause other problems in the future? I ask because I just pulled my trans on saturday to get it rebuilt and if it would be a good idea to replace it I would like to know. Thanks.
1986 CAMARO Z28 ->
151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframe connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH 3300lbs less driver and speakers Next mods-> B&M shifter, Extreme Energy 230/236 cam, Holley street dom intake.
1987 TRANS AM ->
73,000 miles, 305TPI, auto, all stock.
Old 03-04-2001, 11:31 PM
Birmass's Avatar
Even if it isn't the problem I would replace the pilot bearing. It's only a few bucks and should have been replaced when you got the clutch done. Usually though it will squeel if it's bad, not chatter. It's possible that the throwout bearing or fork is causing the noise. Might not have been lubricated correctly.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
All your base are belong to us.
Old 03-06-2001, 08:14 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
When I got my 81Z the clutch slipped sometimes (those more gas than clutch times). I bought a new clutch and pressure plate, throwout bearing and pilot bushing. The p bushing in the car was totally wore out (you could put your thumb into it). The clutch was not wore out, but it slipped, it did not chatter.
Z's r Best
xxx3man`
09-23-2015 10:37 PM
theshackle
08-31-2015 10:47 AM
TEEZER TA
08-30-2015 06:35 PM
19irocz85
08-26-2015 07:54 PM
rsrmoore
08-07-2015 08:44 PM
Quick Reply: Will a bad pilot bearing cause clutch chatter?
