600 for installation wtf
Old Mar 8, 2001 | 02:42 PM
1989camarorsrs's Avatar
i just called the tranny shop to see how much it is for them to install 3.73 gears or 3.90s and he said about 600-650 "thats a big jump from 2.73s" is it realy that much money damn
Old Mar 8, 2001 | 03:35 PM
Ringmaster72's Avatar
Car: 1989 IROC
thats way too much. I had gears put into my 12 bolt last year and it only cost me $100 in labor. I also got a quote of about 150 from another shop.
Old Mar 8, 2001 | 03:38 PM
im not sure of a place to go to what should i look under in the yellow papers thanx
Old Mar 8, 2001 | 03:41 PM
86SCBNJ's Avatar
Well, what is included for that price. Is it just a gear swap or is it a rebuild/replace the posi unit?? Are all the bearings being replaced?? Any tranny shop can do a cheap gear swap, u need to find out what u are geting for your money....
86 SC, 305 LG4, TH700R4, SLP headers, 3" cat and exhaust. Mild cam 204/214, .423/.442. SLP shift kit, richmond 3.73's w/limited slip. Susension Technique Sway Bars, Globel West Wonderbar, Poly everything bushings, Metco LCA's, Lakewood Panhad Rod. 16" ROH, with Toyo 245's. For autocross, 16" IROC's w/bfg R1's... Need more speed.....
Old Mar 8, 2001 | 03:57 PM
yea the guy said hes that price is with all the bearings and parts i didnt know the posi had to be rebuild or changed, can i just get a gear swap or is all that other stuff needed
Old Mar 8, 2001 | 04:29 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
If labor and parts are included that is a good deal . What really should be of importance is quality. Go to a place with a good reputation as far as quality work.
Big 454 72 Chevy Nova
383 86 Camaro Z28
Old Mar 8, 2001 | 05:21 PM
so 600 total not that bad yea it includes parts and labor
Old Mar 8, 2001 | 10:33 PM
and what will 3.90s reduce ure max speed too just wondering and about how much worse on mpg cause i get rite now about 8 mpg kinda sux for a 305tbi i dunno
Old Mar 9, 2001 | 07:09 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I'm seein' a big greasy man named clem taking a 16 lbs sledge to 'persuade' the carrier into the housing and using the edge of his roachclip to check pinion depth and backlash @ $100 labor.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
[This message has been edited by JoelOl75 (edited March 09, 2001).]
Old Mar 11, 2001 | 12:53 AM
hahhahahah
hahahahaha
Old Mar 11, 2001 | 01:08 AM
rhawki's Avatar
Joel, that was great - setting clearance with the roach clip! Umm i mean, what's a roach clip?
1989camarorsrs:
8 mpg on a 305? I get better than that on my carbed '74 350 - get close to 20 highway! And that's after heads, cam, etc... Are you towin a dumptruck or somethin?
-Rich
Old Mar 11, 2001 | 07:22 PM
Car: 86 z28
A roach clip is a mehcancical tool used by automotive technicians to help them release tension resulting in quality work .lol
383 86 Camaro Z28
Old Mar 12, 2001 | 12:32 PM
Car: 1989 IROC
well, ASSES I had my rear done a year and a half ago in my 68 Camaro and its been around 18,000 miles since then on the new gears, diff., bearings and seals. So if it was in fact a guy with a sledge then he did a damn fine job.
Old Mar 12, 2001 | 12:52 PM
Aaron87SC's Avatar
Lighten up there cranky...
deracer
Apr 11, 2016 12:04 AM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
Cacike
Aug 27, 2015 05:10 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
86IROC112
Aug 17, 2015 02:00 PM
