AXLE REMOVAL-HELP ME PLEASE
Old Mar 15, 2001 | 08:30 AM
BOXOFROCKS's Avatar
I have a 88 Iroc 9 bolt posi rear with leaky seals. Wanted to change myself but can't figure out how to get it apart. Can someone give me instruction?
Old Mar 15, 2001 | 07:44 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Take off wheels, take off brake calipers, take off rotors.... Stick a ratchet through the hole in the axle flange. Spin it to get all 4 bolts on each side. Pull the axle out. Might need a slide hammer but I didn't. Might also need a rotor puller (i did) before you put the rotor back on make sure to anti-seize the inside where it sits on the axle flange... it's worth it. I broke my puller and didn't budge the rotor! Needed to borrow torches!
The seals arnt too bad. Put a thin film of silicone on the outside before you drive em in.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Old Mar 16, 2001 | 12:07 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
<font face="Verdana, Arial" size="2">Originally posted by JoelOl75:
</font>
You had bearing retainers on the outside like ford housings??
I thought all 3rd gens had c-clips.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Old Mar 16, 2001 | 12:36 AM
87RS402's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Engineboy:
</font>
So did I.
Old Mar 16, 2001 | 12:58 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
9-bolts dont have c-clips, only 10-bolts do. Another reason why 9-bolts are stronger.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 16, 2001 | 09:26 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Huh, I'll have to check out my freinds GTA.
Learn somethin new every day.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
6speedIROC
16
Mar 15, 2023 08:33 PM
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
