My 700R4 shifts to 4th too early-WTF??
Car: 84 T/A
Engine: 305HOL69
Many have posted about the 4 to 3 downshift at WOT-I have the opposite problem and it's pissing me off!! If i'm going about 30-35 it stays in 4th, no lockup. As soon as I start into the throttle again, WHUMP, i'm in 4th lockup and lugging & chugging until I go about 3/4 throttle. Then it slams back into 2nd and hauls *** . Is this something that can be corrected on the ECM, or should I just put in a switch to kill lockup when i'm at this speed? I know 4th needs lockup after about 45-50mph, but I hate it when it comes in this early. I should have gotten a manual.
DR Stevens
Car #1: my ride
1984 TransAm
305HO(L69) 96K & counting
750 cfm Q-Jet/Holley rem.
K&N filter
700R4/Superior shift-kit
and trans cooler
3.42 rear/3.73 blew up!!
underdrive pulleys
Accel HEI Super-Coil
180 stat/hi flow water
pump/Jet fan switch
dual snorkel/'84 ram air
3" exhaust of some sort
partial emissions delete
Car #2: My wife's ride
1991 Firebird/Formula
305TBI(LO3) 99K & smoking
K&N air filter
Hypertech Chip
more engine mods later
"Hey, Uncle Sam!! Where's my f**king tax return??!!"
DR Stevens
Car #1: my ride
1984 TransAm
K&N filter
and trans cooler
underdrive pulleys
pump/Jet fan switch
K&N air filter
Hypertech Chip
Car: 88 Firebird WS6
There is a spring in the valve body for the 3-4 sequence valve. Possibly swapping in a heavier spring will raise the shift point for 4th. They usually go into 4th at 35 to 40 mph anyway. I'm not sure what spring to put in there, nor do I know where to get one.
Maybe someone who knows about modding them can hook you up, because trial & error on dropping the valve body isn't much fun.
I will post you a pick of the location of the valve if you want.
It doesn't sound abnormal though (at light throttle anyway) for a 4th shift at 35 but it could be changed.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
'88 Camaro RS 2.8L
Car: 84 T/A
Engine: 305HOL69
Well, what seems to happen the most is that the lockup comes in at these low speeds and really bogs things down-I don't mind 4th gear at about 35mph, but then it locks up and really lugs the engine, and it don't wanna UN-lock until I stand on it; not fun in city traffic which I often encounter. I know I could put in a switch and manually operate the TCC, but will I harm my tranny doing this? I just don't want that friggin lockup until about 45-50 mph, that's all.
DR
DR
Yep, a switch would be ok... Just make sure you don't leave it off for long highway drives... An external cooler would be a good idea. I heard of overheating running 4th unlocked for long periods of time but a good cooler should do the trick. A custom prom can be made to raise the lockup point also, or using a vacuum switch will raise it depending on engine load. You can jury rig a vacuum guage to your windshield and find the right vacuum point you want lockup to occur, then wire it into the tan or the red (but not both) wire on the trans harness.
Just some ideas. I wired mine to lockup all the time in 4th. With 4.10's and a ZZ4 there's really no bog (even up a pikes peak type hill) but my v6 has the problem you mentioned. And instead of unlocking the tcc while bogging it kicks down into 2nd! I think it's wasting more fuel and defeating the whole purpose so i resort to driving in 3rd gear unless on the level.
'88 Camaro RS 2.8L
'88 Camaro RS 2.8L
Car: 84 T/A
Engine: 305HOL69
THANK YOU Joel, I was hoping to get this answer. I would only leave it unlocked while driving in the stop-n-go clusterf*ck traffic that we get around here, you know how that goes. Never gets much above 45mph. I already have a tranny cooler, mounted it front 'n center of the condenser, and it really did make a difference in the shifting, nice & firm the way the kit is supposed to make it.
I thought there were no bins to make a custom prom for a compucarb ECM? Or did I miss something?
UPDATE/EDIT:Switch did the trick, it helps with kickdown, too.
DR Stevens
Car #1: my ride
1984 TransAm
K&N filter
and trans cooler
underdrive pulleys
pump/Jet fan switch
K&N air filter
Hypertech Chip
[This message has been edited by eightTfourTA (edited March 27, 2001).]
DR Stevens
Car #1: my ride
1984 TransAm
K&N filter
and trans cooler
underdrive pulleys
pump/Jet fan switch
K&N air filter
Hypertech Chip
Car: 84 T/A
Engine: 305HOL69
Remember what they say about the word 'assume', it makes.......you know the rest Yeah, I just put a switch inline with the TCC brake switch, purple wire. Best $2.39 I spent yet!
DR Stevens
Car #1: my ride
1984 TransAm
K&N filter
and trans cooler
underdrive pulleys
pump/Jet fan switch
K&N air filter
Hypertech Chip
DR Stevens
Car #1: my ride
1984 TransAm
K&N filter
and trans cooler
underdrive pulleys
pump/Jet fan switch
K&N air filter
Hypertech Chip
In bad traffic, it is a good idea just to drive in 3rd...makes for a lot smoother drive.
Mike Metzler (Desert86Roc)[*] Webmaster: SpeedWorldMotorplex.com[*] Click Here For 86 IROC 305 TPI (406 build in progress) Page
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.365 @ 86.785 mph (uncorrected, headers, no NOS)
Did you try adjusting your TV cable. Just a few clicks out of adjustment played havok with my trans.
A switch may only prolong the inevitable.
89 Formula 305 TBI
160* stat, 200* fan switch, K&N, Headers, 3in Flowmaster (hollow cat) back, pullies, 1.6 full roller rockers, B&M trans cooler, home-made ram-air
3.73 Richmond gears and SLP Zexel Torsen Posi (waiting for install)
89 Formula 305 TBI
Car: 84 T/A
Engine: 305HOL69
Yeah, adjusted the TV cable a couple of times, it's right where it's supposed to be. I took the car to my tranny mechanic, he says it's just fine, it was rebuilt about a year ago with all the cool performance goodies (shift kit, vette servo, etc) I've resorted to driving in 3rd before, but that's a real pain in the *** with the weird stop-go-punchit-stand-on-brake traffic here in Otown. I didn't like how it kept on feeling like it was constantly "pulling". Ah hell, I've solved my problem, thanks everyone. If I burn up my 700R4 then GOOD RIDDANCE, hello t-56.
DR Stevens
Car #1: my ride
1984 TransAm
K&N filter
and trans cooler
underdrive pulleys
pump/Jet fan switch
dual snorkel/'84 cowl
K&N air filter
Hypertech Chip
[This message has been edited by eightTfourTA (edited March 28, 2001).]
DR Stevens
Car #1: my ride
1984 TransAm
K&N filter
and trans cooler
underdrive pulleys
pump/Jet fan switch
K&N air filter
Hypertech Chip
Zeek1041
Theoretical and Street Racing
09-30-2015 11:00 AM
TheTraut88
09-07-2015 05:22 PM
rudolphschenker
09-04-2015 02:41 AM
