Alternative tras
Old Dec 16, 2008 | 11:25 AM
malcom's Avatar
Alternative tras
Hello all-hope I'm in the right board-I own a 1984 z-28 which came with a 305ho-and a t-5 manuel transmission(5 sd).Being unempressed with the power I replaced the engine with a 383 stroker+-350-400hp,missed a gear last summer and hence blew out the trans.Is there a cost effective alternativ e to the weak t-5?One can go to Jegs but the cost is prohibative-2-3k.Any suggestion would be appreciated.Thanks
Old Dec 16, 2008 | 12:39 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Alternative tras
If you don't mind loosing a gear you could locate a Muncie 4 speed somewhere. Should be a few in Salvage yards. Otherwise you go to a Turbo 350/400 or get a beefed up TCI or B&M 700 r4 auto. Seeing as you are used to a manual, the Muncie 4 speed would probably be your best bet.
Old Dec 16, 2008 | 12:43 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I propose you spend $700 for a new Tremec 3650 out of a new Mustang, get an adapter plate made, and go that route.
That trans will hold 460 rwtq with slicks, and you get to have an overdrive.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
