700r4 reverse manual valve body instalation
Old Dec 19, 2008 | 05:09 PM
murd450's Avatar
Car: 83 Z28
Axle/Gears: 4:11:1
i just got a tci ful man reverse shift valve body !any one have any tips for installing it ?????
Old Dec 19, 2008 | 10:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 700r4 reverse manual valve body instalation
Follow the instructions
Old Dec 21, 2008 | 01:40 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
I've installed some of these and probably the most simple thing that gets overlooked during the install is to hook up the manual valve before you install the new valve body or you have to pull the valve body back off or fumble with the shift linkage which isn't easy.
Old Dec 22, 2008 | 11:24 AM
Shagwell's Avatar
Car: projects.......
Plus, if this is a street car, enjoy the shortened life of your trans pump and planetaries.
edit: not tryng to be a d*. Stephen's response just gave me a good laugh for the day.
Old Jan 19, 2009 | 08:43 AM
murd450's Avatar
Car: 83 Z28
Axle/Gears: 4:11:1
not a street car any more !!! how do you take care of the hole frome the tv cabel????since it dosent need it any more it allso just got a b&m hole shot 3000, and to make a 700r4 work in a hi power app you need a good gear im running 4:11:1 i got a 1.68 60ft time but have not been abel to make a full pass as the original trany came apart (original trany 1983)no second no 4th it would go into second then go stait to 3rd and then slip realy bad in third for a best pass of 14.16,at 94 mph i cant wate to see what it will do with a good trans
Old Jan 19, 2009 | 02:11 PM
Shagwell's Avatar
Good luck getting the TC to work well. They're known for being highly in-efficient. (sorry man, most B&M and TCI stuff for 700r's is junk)
Plenty of guys keeping 700's together on steeper gears, they just have to be built right. - Sounds like your original one burned up the band. With a full manual vb and mostly race oriented I would reccomend the billet servos. Good alto or raybestos clutches/band, a hi-output pump slide spring if rpm is over 5500, dual cage(late model) sprag, beast reaction shell - hard to say about the rest w/o knowing a lot more about the combination.
Good luck with it.
Old Jan 19, 2009 | 07:07 PM
murd450's Avatar
Car: 83 Z28
Axle/Gears: 4:11:1
the trany is a recent rebuild ! the trany is mid build ,it is 30 spline but no secondary valve body ,so as close as i can tell it is originaly 85-87 the guy i got it frome says it is a tci trans and only had about 10000mi on it ,the car it was in was a trans am ,late 80's i was told it was a gta and was wraped around a tree ,but i alls o got the rear (been gon for 3 years now ) but the rear was not a 9 bolt so i dont think it was a gta
Old Jan 20, 2009 | 07:57 AM
Shagwell's Avatar
If it wasn't a 9-bolt it wasn't likely a late 80's GTA. - Not sure about the manual vb to say whether or not nat having the aux vb is going to be an issue. W/o knowing for 100% certainty what parts are in it, it's hard to say whether or not it will last long. - If it's just a TCI rebuild/streetfighter you'll probably kill it within a season of racing.
If your rear is a stock take out with (would be 4.10, not 4.11 for a 7.5" 10-bolt)that low of gear, it will likely not take much power if you hook it up.
Sorry to "rain on your parade" so much. - like I said before, good luck with it.
Old Jan 20, 2009 | 09:36 AM
murd450's Avatar
Car: 83 Z28
Axle/Gears: 4:11:1
it is stock housing but not stock gear ,i got the gears frome a frend ! i installed them , i looked for the company that made them and i couldent find the maker on the gears , i have never seen a set of 4:11's advertised just 4:10's but i ashure you they are 4:11:1's! i hope to find a th350 this year i want to build one with a trans brake , and ure not raning on any parade i know it is a week trans
Old Jan 20, 2009 | 12:07 PM
Shagwell's Avatar
Being aftermarket gears won't help it. It's still a tiny 7.5" ring gear, thus to go lower(numerically higher) than 3.73 requires a very small pinion gear. The smaller the pinion gear, the less the tooth contact area between the ring and pinion. The less the contact, the greater the stress. - It will break, it's just a matter of time. If you go a t-brake, it will break soon.
GM left us screwed on driveline. The aftermarket stepped-up, but it costs.
Old Jan 24, 2009 | 12:25 AM
ed o's Avatar
Axle/Gears: 3.36
there is are some trans brake v.b.'s made for a 700r4 but they work differently than the th350.
of the th350's that you would want-it'd be the long one because the driveline could stay the same length. Use the long 9" TH350 not the 6". Note that the yolk would also be the same so that would be an easy swap with the 9" one.
Old Jan 27, 2009 | 04:56 PM
murd450's Avatar
Car: 83 Z28
Axle/Gears: 4:11:1
ow i know it wil break i have gone through 3 sets of gears and and 2 carriers, it is starting to look like i need an aftermarket rear,they are just so dam exspesive , and i read and artical on the 700r4 trans brake and it dident say allot of nice thing about it ,in one of the trials it actualy broke the housing just after it was engaged ( while wating on the yellows) and the only 700r4 trans brake i could find was $900 as aposed to the th350 witch was as low as $375
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
TreDeClaw
Aug 14, 2015 06:58 PM
