pro 5.0 shifter on tko 600
Old Dec 20, 2008 | 03:25 PM
huffediroc's Avatar
Car: 87 iroc
Engine: 350 with weiand 144
Transmission: tremec TKO 600,mcleod street twin
Axle/Gears: strange s60
If I put on a pro 5.0 shifter on my tko 600 will it sit back a little further so I'm not hitting the console on my shifts? The tko never came with a shifter shaft so I've been using one off an old transfer case. I hear alot of good things about the pro 5.0's, will this solve the problem? Also the tranny is sitting proper level with spohn x member and d loop.
Old Dec 22, 2008 | 09:30 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Re: pro 5.0 shifter on tko 600
No, it will actually sit in the same spot. What you have to do is make a small plate to move the shift lever back about 2" IIRC. I made it out of aluminum and used a Hurst shift lever, it was the right length and color. Try to make it so the lever ends up in the center of the console in neutral. With the short throws on the Pro 5.0 it won't hit anything.
Old Dec 26, 2008 | 06:19 PM
huffediroc's Avatar
Car: 87 iroc
Do you mean like a little square aluminum plate say about 2 " by 2" with 4 holes. 2 for the shifter and 2 for the stick? So the plate actually attaches the shifter stick to the stock tranny shifter but setting it back 2"?
Old Dec 26, 2008 | 06:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yes
i was also looking into the tri-ax shifter from steeda. It has a handle that is swept back and looks like it may work. I just dont know is the stick is long enough.
this one
http://cgi.ebay.com/ebaymotors/Steed...ehicleQ5fParts
i may buy it soon.
Old Dec 26, 2008 | 09:36 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
the mustang shifter "handle" is nearly a perfect fit in these cars. I have a pro 5.0 shifter on an older TKO with a mustang short handle. works great
Old Dec 27, 2008 | 08:53 AM
huffediroc's Avatar
Car: 87 iroc
Can I get away with just buying a stick like that or do you have to get the whole shifter? Does the stock tko shift have shift stops?
Old Dec 27, 2008 | 11:06 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
the trans has internal shift stops, i dont think they're in the shifter, i made a handle by cutting and welding using an old long hurst truck handle
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
tmellott89
Oct 14, 2015 02:06 PM
Drone358
Sep 28, 2015 04:55 PM
ndndndnd
Sep 28, 2015 08:00 AM
89bird2.8
Sep 22, 2015 05:28 PM
