Stock Tranny from 305?
Old Dec 26, 2008 | 03:33 PM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
Transmission: Auto 700R-4
Hey,
can anyone tell me what the transmission would be in a 1990 RS with a 305 V8? Was there any variation in transmissions in that year or engine or were the trannys that were put in them all the same?
-G. Martinez
Old Dec 26, 2008 | 03:51 PM
blp226's Avatar
Re: Stock Tranny from 305?
It will be a TH700R4. I know they put 200R4s in some of them back in the earlier 80s, but I'm pretty sure yours is a 700. Assuming it is an auto car to begin with. The 700R4 is a good sturdy 4 speed tranny. They are probably the perfect tranny for a street/strip musclecar. It's more than strong enough for your 305, even if it's hopped up, and it will give you fairly good highway cruising gas mileage.
You should go to your local part house and get a HAYNES or CHILTONS book for your car. It has all the speck you'll ever need for that car.
Old Dec 26, 2008 | 04:23 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
700R4 was the stock automatic used with all varations of the 305's and the 350. They were all the same.
Old Dec 26, 2008 | 05:49 PM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
Thanks for the info, its good to know what I have in it. I figured thats what it was. The reason I was asking is because I bought the car this past summer from a guy who had replaced the TBI 305 with a Carbureted 350 out of a 1985 chevy pick-up. I"m planning on getting the engine rebuilt next month but was told that the tranny might not be able to handle the power from the rebuilt 350. I don't plan on doing a while bunch of mods with the rebuild but I want to get her bored .30 over and possible go up one notch with the cam. I also plan on rebuilding the 650 cfm edelbrock that is already on there and also putting in a new, possibly a slight high-rise, intake manifold. Does anyone think that I would have a problem with the 700R4 with the rebuilt engine?
Old Dec 26, 2008 | 06:02 PM
DJP87Z28's Avatar
NO... unless you do something stupid.
Old Dec 26, 2008 | 06:09 PM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
...what exactly do you mean by stupid?
Old Dec 26, 2008 | 07:32 PM
DJP87Z28's Avatar
When you do it you will know and then you will slap your head and say I am stupid.
Old Dec 26, 2008 | 07:46 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
...like revving it up in neutral and throwing it into gear?
that sure would fudge up a good tranny
go stick shift, lol
Old Dec 26, 2008 | 07:59 PM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
I'm pretty sure I'm not going to be making any stupid mistakes like that. I'm not looking for a street racer here. I just want to make sure that for daily driving and even opening her up once in a while (and I don't mean once a day) will not tear up my tranny.
On another note. The 700R4 that is in there is giving me a few problems as it is. After she warms up and i put her in D it throws it into gear so hard the rear tires jolt and then when i'm driving her when she's cold in D it takes a LONG time for her to shift. Not sure what the RPMs are because my tachometer isn't working right. any suggestions?
Old Dec 26, 2008 | 09:27 PM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
Check to make sure the TV cable is adjusted properly (???)
FWIW, there are many 350 powered f bodies that came from the factory with the 700 R4, so I wouldn't worry about the trans holding up. Well, if the trans is in good condition to start with, that is.
Old Dec 27, 2008 | 01:02 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
700r4, in 82 and 83 i believe they used 200r or 200c, i forget it but i know it didnt have overdrive. a good 700r4 should handle an assload of horsepower if taken care of properly, no neutral drops, and no long burnouts
Old Dec 28, 2008 | 12:53 PM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
beaner good englix. you drive a proper camero. where I live you can't mod a engine like that-smog. overdrives yes. a fst car you have not yet-the trans is overkill-go BIGGER/smog must not apply to you in mexico.?
Old Dec 28, 2008 | 01:57 PM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
the 700r4's are different through the years. if you have the original 90 700r4 that is a good one, if you got the 85 700r4 with the motor...well not as good. but you are using the car as a driver and either will work for that. spinning the tires is not as bad as the car hooking hard and lifting the frontend...that will test a tranny.
Old Dec 28, 2008 | 11:17 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Nope, they never put 2004R's in thirdgens, except in the '89 Turbo Trans Am. The 82-83 3-speed automatic was the TH200C and the later 4-speed overdrive automatic is the 700R4.
gta90
Sep 15, 2015 04:00 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
marcusaw
Aug 10, 2015 08:13 AM
drathaar907
Aug 6, 2015 04:20 PM
