What tools needed for 700R-4 removal??
Old Apr 4, 2001 | 11:11 AM
fast89's Avatar
I am going to begin removing my 700-R4 trans and I am wondering what the tools for success are?? I heard a long extension is needed, but is there anything else that would help?
1989 Pontiac Formula L98 Ported Plenum, Edelbrock 6085 Heads, Edelbrock HI-FLO Intake, BBK 52MM TB, Edelbrock TES, FlowMaster 3" Exhaust, Dual Cats, 3.27 Gear, CompuCam 2032 Cam, 1.5 Rollers, Ed Wright FastChip, Accel Super Coil, MSD 8mm Wires
Old Apr 4, 2001 | 11:44 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Basic hand tools is about all you'll need - and some patience. You'll have to remove a few things that are in the way, but again, basic hand tools. You'll need both std. and metric tools. I don't know how you're going to drop the tranny itself, but if you're using a floor jack, a nice piece of wood about the size of a tranny pan will be very nice to have. I made my own "cradle" out of wood before I even got started to pull it out. Also, the forward part of the pan is about the center of balance...
KAM
[This message has been edited by thunderstick (edited April 04, 2001).]
Old Apr 4, 2001 | 01:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Use a tranny jack. I got one from Harbor Freight for $50 - cheap, but gets the job done. Or rent one.
I've tried the floor jack routine: I'm feeling better now, thank you.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Apr 5, 2001 | 07:29 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Various long and short extentions and wobbles let you get many of the bellhousing bolts from under the car. I think there's one on top by the passenger side I had to get with a wrench because of the dipstick or something. Wobbles that are spring loaded or those nifty new snap on ones that have the socket built in are better because they don't go floppin and slippin all around.
Old Apr 5, 2001 | 08:47 AM
Car: '91 Z28
Axle/Gears: 323's
<font face="Verdana, Arial" size="2">Originally posted by five7kid:
...I've tried the floor jack routine: I'm feeling better now, thank you. </font>
Ouch... sounds like you had an accident... When I used my floorjack and made a cradle for it, I cut the wood to the same size as the pan, then put blocks on the front and sides, and then put blocks on the under side, spaced apart the same width as the "cup" on the jack. That way the cradle stayed in position but I could slide it back and forth only if I had to. With 2 people, it worked out really well. The second time I had to R&R it, I was alone on the install part of it, but that cradle on the jack worked like a charm for me... Just my personal experience...
KAM
Old Apr 5, 2001 | 08:54 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
Make sure to have plenty of beer, and a second hand (friend). I have a three foot extension and a universal that allowed me to get to all of the bolts. You'll also need a (I think) 15 mm wrench to remove the three toque convertor bolts. A large screwdriver to wedge in the flexplate to keep it from turning helps when taking thes bolts out.
Come to think about it, 150 pound transmission, floor jack, jackstands.....maybe the beer should be for after the job is done.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old Apr 5, 2001 | 10:28 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
YES! That 3 foot lonng extension & swivel is a god!! Make sure it's a thick 1/2 inch drive unit, and not the thin 3/8 inch stuff that comes in a socket set. I had a lonnng 3/8" extension that wasn't working- the thin thing was twisting up and absorbing my torque.
I just unbolted the trans from a 2.8 (since we were doing an engine swap). Visit one of my "update" posts here: https://www.thirdgen.org/messgboard/...ML/001226.html I give the exact assembly of tools to use. Remember- this is for the smaller version of the 700r4 (for a V6), so I might've had more room than you will.
Oh- when I actually swapped the trannies on my '86, I too made a wooden adapter to connect the trans to my hydraulic floor jack. It wasn't as complex, but it was a board with another thin board screwed to the front. That thin board went directly in front of the trans pan, so it rested on the trans case. Then I "guessed" at the center of gravity for the trans, and put the hydraulic jack up. I guessed pretty well! Next time I do this, though, I want to buy the trans jack. The thing was very hard to made with the engine using my homemade jack.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
[This message has been edited by TomP (edited April 05, 2001).]
Old Apr 5, 2001 | 02:27 PM
five7kid's Avatar
Well, the tranny took a thump on the garage floor. Went back in with a rented tranny jack, got my own for the next round.
As for feeling better, it's the medications...
A 9/16" universal joint socket on the longest Craftsman 3/8 drive extension available did the job for me. I'd recommend getting the socket rather than just putting a standard socket on a u-joint.
I still haven't found a drain pan that will fit under the entire tranny pan (other than those big, flat pans with virtually no sides). Put in a drain plug while the tranny's out.
Old Apr 6, 2001 | 11:27 AM
Car: '91 Z28
Axle/Gears: 323's
I still haven't found a drain pan that will fit under the entire tranny pan </font>
A kitty litter box works pretty good. A new one of course...
KAM
Old Apr 9, 2001 | 12:55 PM
five7kid's Avatar
<font face="Verdana, Arial" size="2">Originally posted by thunderstick:
KAM
</font>
That's what I've been using. Long enough, but not wide enough.
IROCZ1989
Jan 24, 2016 03:55 PM
TheExaminer
Aug 25, 2015 07:34 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
3rdgenparts
Aug 8, 2015 07:09 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
