Transmission or clutch problem?
Old Jan 2, 2009 | 02:06 PM
DarrensCamaro's Avatar
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
Alright guys I think I am having a trans or clutch problem in my 1992 RS 305 TBI 5 speed camaro. I was hoping you guys would be able to point me in the right direction of where to look or go to first. So heres the problem: Either from a dead stop or while rolling if I get on my car the RPM's rev real high before the car will get up and go. This only happens sometimes and if I drive the car normal just out driving around town its fine. This only happens when I get on it a little, so is it my trans starting to go? Or is the clutch not engaging or letting go or what? Any help is apprieciated since I was getting ready to send this car to paint but now I want to make sure its mechanically sound before I do that. Also this is kinda a newbie question but I am a newbie I was wondering what kind of trans was in my car, it is a 5 speed...
Thanks,
Darren
Old Jan 2, 2009 | 02:46 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Transmission or clutch problem?
clutch and pressure plate. Sounds like the clutch is slipping.
Old Jan 2, 2009 | 11:24 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
well thats much better then someone telling my transmission was going bad. So I have never replaced a clutch before is it hard? I've never worked on a trans or clutch before any tips?
-Darren
Old Jan 3, 2009 | 11:17 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
if it was an automatic trans, it could be the trans going bad, or the torque converter.
since its a manual its a bit different. The t5 is just a gear box, the gears dont slip inside of it, they either work, or they break, and if they are broken , the gear or trans wont work at all.
Changing the clutch is just a matter of unbolting things and rebolting them. Problem is, some of those things are big and heavy. the hardest part is getting the trans out. If you have a lift and proper tools, its not a big deal, but if you are doing it on the garage floor with the car on jackstands, prepare for a tremendous upper body workout.
Its all come down to you mechanical ability and what tools and facilities you have at your disposal.
If you dont want the hassle, take it to a reputable shop and have them do it for you.
Old Jan 3, 2009 | 11:27 AM
Car: 1992 Camaro RS
Engine: 350 Carb'd
You have to take the trans out to replace the clutch? If thats the case then I will probably just take it in. The car is still drivable just acts up when I got on it or accelerated fast so are we pretty sure this is a clutch problem? I guess if I took it into a shop they would be able to tell me.
Thanks,
Darren
Old Jan 3, 2009 | 11:34 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Slipping clutch problem and it is not going to heal itself. Easy driving lets the clutch engage without to much slipping. It is only a matter of time.
Old Jan 3, 2009 | 11:41 AM
Car: 1992 Camaro RS
Engine: 350 Carb'd
Yes I know but when the car is your DD and you are a broke college student that works hard and still lives check to check sometimes a little easy driving until you get paid is what you gotta do.
Old Jan 3, 2009 | 11:59 AM
Car: 1992 Camaro RS
Engine: 350 Carb'd
Any recomendations on a good clutch to buy?
-Darren
Old Jan 6, 2009 | 08:05 PM
Pat Hall's Avatar
Since your car is basically stock, you'd be just fine using the Ram Premium replacement clutch. The Ram Premium series is equivalent to the OEM clutch, but far better quality than the original. It's about $140 and should be more than adequate for your needs. Here's a link on where to buy one. http://store.summitracing.com/partde...5&autoview=sku P.S. Make sure the shop resurfaces your flywheel when they put the new clutch in.
Old Jan 6, 2009 | 10:41 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
I actually think that is the exact one that the shop purchased to replace my original. I will have to look at the bill but I do remember him saying RAM and that it was better quality then the OEM replacement. I had the work done today and yes he did resurface the fly wheel. He also ran into a few minor problems with a leaky seal on the front on the trans so I had him replace all the seals, slave cylinder and a few other odds and ends. I have only owned this car for 3 months and I have to say the clutch had to be bad then because when I got the car back today it was a world of a difference. I had to learn how to drive the car all over again, much better power at the pedal and it actually hooked up! I was incredibly excited and pleased, thanks for all of your help identifying this problem and the recomendations. I just wish it wasnt so cold wet icy and snowy outside and I would have been able to tackle this problem on my own!
-Darren
Old Jan 7, 2009 | 02:33 AM
Pat Hall's Avatar
Good deal man! It sounds like you picked a good, reputable shop to do the work for you. It's good that they fixed all the leaky seals too. Sometimes that can saturate the clutch disc and cause it to start slipping too, especially if the seal inside the bearing retainer, or the engine rear main seal are leaking.
Old Jan 7, 2009 | 09:09 AM
Car: 1992 Camaro RS
Engine: 350 Carb'd
This was actually the first time I used them, they where recomenbed by a friend who had his trans rebuilt there. The rear engine seal was also replaced, they said it wasnt leaking but it looked like it could start any day and hey they were right there so why not right? But I was extremly pleased the best part was they did this all in half a day! But since I have owned the car the clutch hasnt been right and now with the brand new one its like driving a whole different car!
Thanks,
Darren
jhawkeye
May 25, 2022 06:33 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
rsrmoore
Aug 7, 2015 08:44 PM
