Powertrax Locker for my 10 bolt
Old Apr 10, 2001 | 10:24 AM
AntiChrist
Guest
Posts: n/a
I've got an '89 formula with TBI and a 5speed. I'm wondering if the powertrax guys are telling the truth when they say that the install is doable by regular human beings. I have the usual hand tools, what special crap might I need? I know pretty little about rear-ends. Thanks.
No guts, no glory.
Old Apr 10, 2001 | 01:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Floor jack, jack stands, wheel chocks, drain pan, gasket scraper, gear lube pump.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" Hedders, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere w/open diff & slipping tranny. Daily driver while Camaro was being put together.
Old Apr 10, 2001 | 02:52 PM
AntiChrist
Guest
Posts: n/a
Hey, thanks for responding.
What's a gear lube pump? It sounds like its a pump for gear lube , but I'm not too sure what to use it for.
Doesn't the gear lube kinda succum to gravity, and fall out of the diff?
No guts, no glory.
Old Apr 10, 2001 | 06:34 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
yeah but you need the pump to put it back in once you seal up the diff. There is a plug on the engine side of the rear that is how you check fluid level and put it back in once it is put back together
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package with 64cc aluminum heads, dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
Old Apr 10, 2001 | 07:40 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
<font face="Verdana, Arial" size="2">Originally posted by AntiChrist:
</font>
I think you should consider changing your screen name.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Apr 10, 2001 | 11:35 PM
AntiChrist
Guest
Posts: n/a
I'll take this time to explain the name. It's nothing religious. I chose it because it's the name my friends have given my f-bird. If you've ever seen the movie "The Gods Must Be Crazy", you'll see why. I saw the above movie in JUNIOR HIGH, so I'm sure that if anything was offensive (i.e. car-names relating to actual anti-christs), it would have been nixed. If you have some deep religious sentiments, sorry. Keep in mind that the name isn't meant to be controvertial, it's just a name.
No guts, no glory.
Old Apr 11, 2001 | 10:31 PM
RICHRAD's Avatar
Christ stands for honesty , love , respect, and the brothers(sisters too) coming together here in fellowship of their F-bodies. Your name will always be looked at for what it is so you may want to seriously consider changing it.
Old Apr 12, 2001 | 12:13 PM
AntiChrist
Guest
Posts: n/a
Hello?
I said that the name had nothing to do with my idea of Christ, christianity, God, or religions. It's a name from a PG movie.
Tell a legend like Ed "Big Daddy" Roth that offensiveness has no place in the car world, and see what he would say.
Old Apr 12, 2001 | 03:20 PM
Tas's Avatar
Tas
So if my car was black(my first one was) then I can name it BigNigga, join thirdgen, and everyone has to accept my new persona, BigNigga???
-Tas
'89 Formula WS-6
[soon to have Hooker 1-5/8" 50 state legal headers installed]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
Old Apr 12, 2001 | 03:29 PM
JPrevost's Avatar
Car: 91 Red Sled
AntiChrist, your name is controversial. You might have explained it to us already but do you feel like explaining it to all 7170 members? Not to mention all the guests. If you don't want to get onto peoples bad sides I'd just change it, why go through the hassle of somebody always posting "what's up with your name" on every thread you open or reply to. I don't care if it's from a movie and if that is your cars name, it's still something that gets under my skin everytime I read it.
, Jon (350 TBI! getting 23mpg highway)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
Old Apr 12, 2001 | 03:47 PM
AntiChrist
Guest
Posts: n/a
JPrevost, how about NTChrist? I'm willing to compromise. You gotta admit, though, that I put up a good fight.
Screw cars, I'm going to be a lawyer!
No guts, no glory.
Old Apr 12, 2001 | 04:20 PM
JPrevost's Avatar
Car: 91 Red Sled
Sounds good. I'll tell Dirk and it'll be done.
  • 8" harm. balancer
  • Alston SFCs
Old Apr 12, 2001 | 05:27 PM
five7kid's Avatar
I'll admit that had I noticed your screen name, I probably wouldn't have replied. I don't take that sort of thing lightly.
Your new suggested name makes it sound like you are the Windows NT Messiah - is that true??
Old Apr 13, 2001 | 09:30 AM
NTChrist's Avatar
I guess so.
Thanks for the responses to the powertrax question.
No guts, no glory.
Old Apr 13, 2001 | 01:25 PM
OLDYELLR's Avatar
Car: '85 IROC
What's a gear lube pump?</font>
It's about the size of a grease gun with 2 tubes on the end. You can use it to pump lube into the rear end or manual tranny from a jug, or pump oil out of a manual tranny. However, you can buy rear end lube in quart bottles (you'll need 2) that have a nozzle on the cap so you can squeeze it in while under the car. It works a lot better if you put about 3" of plastic tubing over the end of the nozzle so you can get the bottle up higher.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Torsen, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Old Apr 15, 2001 | 03:21 PM
IROCracer's Avatar
NT....I would have said "F-off" let's cry about a screen name a little more.
If he really wanted to use that name to offend people, he probably would have went to soem religion board....not thirdgen.
KElly
If you've gotta fix it, fix it better than stock.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
dbrochard
Oct 3, 2015 12:43 PM
dbrochard
Sep 19, 2015 08:13 PM
Nick McCardle
Sep 10, 2015 08:36 PM
