4l80e swap from old 700r4
Old Mar 11, 2009 | 11:37 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
anyone ever done one, im doing a turbo motor and gonna make some pretty high numbers and i cant relly on a 700 to do the job even at level three they are just at 75o horse rated...
and the car is a driver, so i need an overdrive, this is where the 4l80e comes in, its basically a th400 with an overdrive stage one with upgraded sprags and drums holds over 1200 horse which is perfect....but i jus dont seem to have enough info on anyone doin this swap...i searched and pretty much nothing, i need to know a few things
is the TC the same
can i use the same driveshaft
crossmember will have to be made right
will i have to mod the tunel to make it fit..
and im goin with a manual valve body so no need for the electonical controler
anyone done this....if so let me know what it took....im pullin the motor to start fabbin in a week or two and id like to swap the tranny b4 i drop teh motor back in...
Old Mar 12, 2009 | 01:11 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: 4l80e swap from old 700r4
Not done it yet but soon, but I have a friend who has done it.
* New TC
* New driveshaft
* New crossmember
thats it.
Old Mar 12, 2009 | 07:34 AM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Have you ever considered a built t56?
did i just read that you dont wanna use a stage 3 700r4 because its rated at 750 and your gonna be making more than that AND drive it on the roads?? dude thats badd a$$ you got any pics or anything to tease us a bit or a thread that we can follow?
Old Mar 15, 2009 | 04:27 PM
Charged350's Avatar
Car: 87 IROC Z28
hey gta, can you get more info from your friend, if you can that be great, what size driveshaft, converter splines are differ i assume, and how hard was it to make the crossmember....and whta did he do with the torque arm...
and as for my car, its a 87 iroc, gettin a big, big turbo on it in the next week or two....im gonna start fabbin up the kit....so i might cracnk the booost up high one day and i dont wanna worry bout the tranny...
Old Mar 16, 2009 | 07:45 AM
Shagwell's Avatar
Car: projects.......
Converter is different, it will likely be the most expensive piece to the puzzle. The driveshaft will need to be shorter(you'll need more than a stocker for that kind of power anyway) and will need the Th400 (iirc 32 spline) yoke, and you will need to fabricate a crossmember. A little modding with a BFH as neccesary for clearnace and you should be fine.
Old Jan 26, 2010 | 06:43 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
not to resurrect an old thread but did you ever put in the 4l80e and if so what driveshaft?
Old May 21, 2010 | 04:18 PM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
nop he never did.... i believe he went 700r4
Old May 21, 2010 | 10:29 PM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Lol figures I'm lookin to a 80 swap too
camaro11j
Sep 19, 2018 08:49 AM
C409
Sep 1, 2015 03:42 PM
Eric-86sc
Aug 24, 2015 09:01 PM
spaigo
Aug 21, 2015 07:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
