Shift kit differences?
Old Mar 12, 2009 | 06:00 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
What are the actual differences between a B&M Performance shift kit, and a Transgo Shift kit.
I don't care to know which is better as everyone seems to favor the Transgo. I want to know the actual differences!
Old Mar 12, 2009 | 06:02 PM
liljon285's Avatar
Car: 1987 IROC
Engine: 5.0 TPI all stock
Axle/Gears: G92 G80
Re: Shift kit differences?
Harder shifts and it holds the gears longer, which is good for passing. My 87 which is a 305tpi has one and i find it more fun to drive than my 89 with the 350tpi. When you put reverse or drive it looks like the car is staging, my second gear chirps once in a while, while driving normal i mean. And overall its just a better gain in performance. Kicks overdrive at around 35mph so i do pretty good on gas too.
Old Mar 12, 2009 | 06:06 PM
Car: 1988 IROC-Z28
Which one are you referring too B&M or Transgo?
Old Mar 13, 2009 | 09:01 AM
Shagwell's Avatar
Car: projects.......
The B&M "kit" consists of two metal sleeves to sshim the accumulators solid, a high pressure pump valve spring and a drill bit to enlarge a couple holes in the seperator plate. All in all, about $5 worth of hardware store stuff. - This set-up induces overly firm shifts at all throttle levels and will eventually beat the planetaries out of the transmission.
The Transgo kit includes a modified seperator plate, HD accumulator springs, a high pressure pump valve spring, the 'vette servo and associated springs/hardware, - that's all I can think off the top of my head(HD pump slide spring for maintaining proper pressure at higher rpm and a low/rev boost valve, iirc). This is not just $5 worth of junk and it allows you to select the proper shift firmness for your application. It incorporates a "firmness curve" (if you will) meaning the harder you're on the go pedal, the harder it will shift. Quick, crisp shifts are great for increasing clutch pack life, but you don't need it to rattle the dash at part throttle shifts.
Old Mar 13, 2009 | 09:04 AM
Shagwell's Avatar
for note: the spring is about the only usable piece in the B&M kit. I've probably got 20 of the sleeves in a cup on my trans bench, which I took out while rebuilding various "performance" trans' built by local shops. - The springs I keep/use as needed, the sleeves are just to explain to the next guy who comes in with his rear planetary trashed.
Old Mar 13, 2009 | 09:09 AM
Car: 1988 IROC-Z28
So even if your just cruising around town, not doing any hole shots, the B&M will still beat your trans to death?
Old Mar 13, 2009 | 10:29 AM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
so the transgo kit will be fine for just cruising as well?
and liljon285, is that hood functioning? i was thinking about getting one with the side vents
Old Mar 13, 2009 | 10:59 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Page 10 shows pars list
Shift Improver Kit Part # 70239
http://www.bmracing.com/bmracing/ins...9500618-00.pdf
Page 10 shows parts list
Transpak Kit Part # 70235
http://www.bmracing.com/bmracing/ins...9500260-12.pdf
TransGo doesnt have any file stating what comes with their kits. They DO however have a video of installing the kit. Maybe that will display the parts list?
http://www.transgo.com/video.php
Let me know if this helps, Ill keep looking.
Old Mar 14, 2009 | 01:44 AM
liljon285's Avatar
Car: 1987 IROC
Axle/Gears: G92 G80
I dont know what shift kit i have, I belive its the trans go, the guy who had both cars built the trnnies right. And the hood believe it or not makes a difference, I have never seen the car go pass 210º!
Old Mar 14, 2009 | 05:34 PM
Convoy25's Avatar
oh ok, i'll check the transgo kit out when its time.
yeah i always kind of leaned towards that style hood because a lot of other people will just get a cowl and i wanted mine to be a little different.
Old Mar 14, 2009 | 06:28 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
And mine with holes
https://www.thirdgen.org/forums/atta...o-dsc03887.jpg
https://www.thirdgen.org/forums/atta...o-dsc03888.jpg
https://www.thirdgen.org/forums/atta...o-dsc03889.jpg
Old Mar 14, 2009 | 06:48 PM
Convoy25's Avatar
yes! thats the exact one i want!
did you have to cut the holes or did it come with?
where did you get it from?
Old Mar 14, 2009 | 08:10 PM
liljon285's Avatar
Car: 1987 IROC
Axle/Gears: G92 G80
At first it was kind of disturbing since not only was i not used to driving third gens but i was not used to this big scoop in the way, but you really get used to it, and when i take it out in the mornings sometimes and the sun glares in through the scoop i can see the Tuned Port Injection plate..I find it very comforting lol somehow.
Old Mar 14, 2009 | 09:26 PM
Convoy25's Avatar
yeahh i think it would be really cool.
somewhat like looking up a girl's skirt.
can't say i've done that though
Old Mar 15, 2009 | 09:40 AM
liljon285's Avatar
Car: 1987 IROC
Axle/Gears: G92 G80
Well when its right in front of you its not like you can look away, lol no guilt in that!
Old Mar 15, 2009 | 03:07 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
The holes were already open when I received it from HTP.
Old Mar 15, 2009 | 03:14 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Who has bought the transgo for the 700r4 and installed it ? What kit did you buy? any snags along the way ?
Old Mar 15, 2009 | 03:44 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Does anyone know how much the transgo kit cost?
Originally Posted by liljon285
At first it was kind of disturbing since not only was i not used to driving third gens but i was not used to this big scoop in the way, but you really get used to it.
X2
Sounds weird but the first time you drive with it on it's like the cowl is in your face but I'd say after at most a week it feels like part of your car and it doesn't look as big as when you first drove it with.
Also people notice that hood, I get a lot of compliments on mine all the time plus it's weight reduction and your engine can roar a little louder.
Old Mar 15, 2009 | 04:11 PM
Convoy25's Avatar
whats htp?
Old Mar 15, 2009 | 07:42 PM
Car: 1988 IROC-Z28
Thanks for the info everyone!
Next question; I was told that there are a couple differnt types of the transgo kit. If so what is that about?
Old Mar 16, 2009 | 01:22 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
jr kit- includes spring and shim for band
spring for pump pressure regulator
springs and seat for 1-2 accumulator
updated throttle valve and return springs
some springs for valve body-to help match kit
2-3 reprogramming kit
option to make it a stick shift only
same green pressure regulator spring
updated t.v.(same as j.r.)
cup plugs for valve body, case, and separator plate
band adjustment shimms(not same as j.r.)
3-2 control valve(in valve body)
some v.b. springs
instructions to modify with drill bits to v.b.
(no servos are included in this kit either corvette or otherwise-----WTF!!!!!!)
(no boost valves are included in this kit either-----WTF!!!!!)
I prefer the J.R. kit because I don't like permanently changing a valvebody or transmission case. You can get firmer shifts with the j.r. kit by drilling separator plate to 2-3specs., installing bigger boost valves in the pump, and installing a better band servo.
Old Mar 16, 2009 | 07:37 AM
Shagwell's Avatar
^ hmm, I was thinking the vette servo was included with one of the kits, but maybe it was just added by the company I order parts from. IDK. The servo is only like $15. - I usually use the Superior "shift correction" package and the billet servos along with various accum spring combinations depending on the application.
Yep. Overly firm shifts, even at low/partial throttle levels = constant pounding on the planetaries.
Old Mar 16, 2009 | 08:03 AM
Convoy25's Avatar
and the transgo kit doesnt do that?
Old Mar 16, 2009 | 09:08 AM
Car: 1988 IROC-Z28
You guys are great!
Thanks again for the info.
Old Mar 16, 2009 | 11:22 AM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
But doesn't the regular SK700 do more then the J.R.? Also how much did you pay for your J.R.?
Old Mar 16, 2009 | 01:14 PM
Shagwell's Avatar
No. It is built properly and creates progressively firmer shifts the harder you get on the throttle. Quick/firm at all throttle levels, but not dash rattling/kneck snapping type shifts like the B&M crap.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
crazynights
Aug 21, 2015 06:53 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
