9-bolt ring and pinion question
Old Mar 16, 2009 | 12:15 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I am looking to buy a set of gears for my 9 bolt and saw two sets listed on summitracing.com here:
http://store.summitracing.com/egnsea...115+4294894011
The Motive set says there are 10 ring gear bolts and the very expensive Strange set says there are 8 ring gear bolts. Is one a typo? How many bolts should there be for the 3rd gen 9-bolt ring year? Could one be for a different application? I'd like to order the Motive set, but want to be sure they're the correct ones.
Also, does anyone know where you can get 3.90 - 4.11 new gear sets for the 9-bolt? The ones sold on 9bolt.com are all used units and are pretty expensive to ship.
Old Mar 16, 2009 | 01:26 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 9-bolt ring and pinion question
Maybe cheaper to swap in a 7.625". Motive makes a 3.909:1 for it, and there's even 4.30:1 gearsets out there.
Old Mar 16, 2009 | 01:39 PM
big gear head's Avatar
It's been a long time since I put a 9 bolt together. I have a set of 2.77 gears sitting on my bench. If I can remember I will check the bolts, but I think it has 8.
Old Mar 16, 2009 | 02:03 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Atilla, do you know where you can find the Motive 3.91 sets for sale? Big gear head, I'd appreciate if you did take a look for me.
Old Mar 17, 2009 | 10:08 AM
The 9 bolt has 8 bolts in the ring gear. I can get you a 3.70 for $170, but that's all. These gears make noise.
Old Apr 11, 2010 | 09:24 PM
chad2233's Avatar
Car: 86 trans am, 93 wrangler
Engine: 350, vortec heads, holley 670
Transmission: t5
Axle/Gears: 9 bolt, currently 2.77
I am new to third gen. trans am. I recently acquired an 86. Its got the 9 bolt which I am also not very familiar with. Currently has 2.73 gear. After locating another 9 bolt for cheap I decided to stay with the 9 bolt. The new 9 bolt has the 3 series carrier that I will need for a desired 3.70 gear. Where can I get a 3.70 for that price if you dont mind me askin? All parts i've found are outrageous.
Old Apr 11, 2010 | 10:14 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Have you checked Randy's Ring and Pinion? They have a 3.73:1 that's a lot less noisy.
Old Apr 11, 2010 | 10:15 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Sorry I didn't see this until now. Summit racing was listing them, I haven't checked recently. Speedway is listing a 3.90:1, but I'm fairly certain that theirs is Chinese.
Old Feb 7, 2011 | 09:08 AM
scottwrightF1's Avatar
Car: 1988 Camaro Iroc / 1989 Firebird TA
Engine: Camaro 350 cid / Firebird 305 cid
Transmission: Soon T56 D&D Viper (WC T5) / WC T5
Axle/Gears: 9 bolts; 3.45>3.89 / 10 bolts; 3.08
Does anyone know where I can find a 3.90 gears for the 9 bolt or who makes a custom gears?
I know 9bolt.com has gears. Just wondering if there are still any update so far.
Old Apr 8, 2011 | 12:04 PM
I got my new 3.89 gear from 9bolt.com yesterday in good shape in the mail like new.
First, I thought it was a 3.90, but is a 3.89 with 35/9 tooth.
Can't wait to install it sometime later.
hectre13
Dec 11, 2023 08:14 AM
lt1z350
Sep 29, 2015 01:50 PM
Mickeyruder
Sep 2, 2015 02:45 PM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
