Something to HELP control Slippage in Auto 700R4
Old Jun 19, 2001 | 02:27 PM
KED85's Avatar
Don't laugh.
I need to add Bananas or Sawdust to control slippage.
It's the 2-3 shift. When colder, it's good. When warmer, not so good, if at all!
I need to pass smog. MAYBE, as is, the tranny will make it.
MAYBE NOT.
What can I add?
I wish I never changed the fluid.
Oh, it is going for a rebuild, so I am not concerned with hurting tranny.
As said on Star Trek, "It's Dead, Jim".
How about Type F fluid?
I am "full" on tranny fluid (due to fresh fluid job) so I am NOT removing any fluid. Just need some over the counter stuff to do the job.
What is it & what store carries it?
Especially in So Cal/L.A. (Go Lakers!) area.
THANKS!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jun 19, 2001 | 03:21 PM
Pro Built Automatics's Avatar
For a quick short time fix to get it to pass smog, drain 2-3 quarts and replace with 40-50 weight motor oil. Have saved a transmission a few times this way. It should give you a few more days till you decide what you want to do. Make sure you reset the TV cable to what transfixleos recommendations are, he has posted several times recently on this.
Hope This Helps!!!
Old Jun 19, 2001 | 03:28 PM
KED85's Avatar
I've now got to figure out, how to drain tranny fluid from the top of the engine.
Because, I am not draining it from below!
These trannys are the biggest pian in the butt for working on them.
My S-10 tranny has alot more room to work with.
Chat Soon,
KED85
Karl
Old Jun 19, 2001 | 06:42 PM
Disconnect the feed line (bottom line at the transmission) at the radiator and use a plastic gallon jug to catch the fluid, when it is 3/4 full stop, reconnect trans line and add 3 quarts of 40-50 weight motor oil. Drive for a couple of miles, it should mixed by then and see if this has helped solve your problem temporarily.
Old Jun 19, 2001 | 09:36 PM
KED85's Avatar
YOU ARE SUCH A GENIUS!!!
Thank you!!
That is about the least messy way to do this!
Gotta try this.
Do you recommend straight 40 or straight 50 OR 20-50 weight?
THANKS
Only wish I could bring the vehicle out that far.
Chat Soon,
KED85
Karl
Old Jun 20, 2001 | 05:17 AM
Straight weight if you can find it. If you use 20-50W, then change 4 quarts instead of 3.
Hope This Helps!!!
Old Jun 20, 2001 | 09:36 AM
KED85's Avatar
Trying to find straight 50 is very close to impossible anymore.
Atleast I can find straight 40 weight!
I really appreciate the tip on emptying the tranny that way.
LOVE IT
Straight 40 it is! 4 quarts! Pep boys here I come or kragen or autozone
Chat Soon,
KED85
Karl
Old Jun 23, 2001 | 01:59 PM
KED85's Avatar
I PASSED SMOG, with the tranny, as is. He kept it in second for the testing.
I passed with flying colors!!
So peaked!
Now for the tranny rebuild!
Chat Soon,
KED85
Karl
BlueIroc-Z
Jun 9, 2019 03:22 AM
jklein337
Sep 19, 2018 06:23 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
TheTraut88
Sep 7, 2015 05:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
