can I make posi?
Car: 85 Firebird & Grand Prix GXP
Engine: LG4 305 (originally 2.8L V6)
Axle/Gears: 10 bolt 3:43 Open Diff.
can I make posi?
So as far as I know I have 323 gears in the axle because it was a v6 car originally and now a 305.
I'm only able to do one wheel peels it seems and was wondering if there is any way to lock the differential?
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: can I make posi?
or a spool, but with a spool you will chirp around turn and just general PITA in a street car
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You can buy and install a posi but it's something that the average person can't do. A Powertrax locker is an easy installation into an open diff that just about anyone can do.
Car: 1990
Axle/Gears: stock
http://cgi.ebay.com/ebaymotors/Camar...05127005r37593 go getum - 125 and you have got it.
for 250 you can get a 3rd gen rear end with disk breaks and posi too - but this is cheaper.
i even found one i like, but cant get it - project for the month is heads and cam.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Tony's ebay suggestion is a good one, though you'll need 28-spline axles to make it work. For a bit more info check the following link about halfway down:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
JamesC
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The summer I had my '88 Camaro, I welded up the spiders. This is called a Lincoln locker, but I used a Miller MIG. Anyway, 3.73:1, 26 spline 7.625", car had a 355/700R-4 combo, on 235/60R15 tires. It was educational, and nothing broke, despite lots of tire chirping and hopping in and out of tight parking spaces, and several passes down the 1/4-mile dragstrip, including burnouts. Still, it's dangerous, illegal, and I won't do it again. $500 for a good posi is far cheaper than any potential lawsuit.
Car: 1992 Camaro
Engine: 350 .030 over 298 cam 9.1 Flat tops
Transmission: T5 swap complete
Axle/Gears: 3.73 posi the 4.10s are history
If money is the issue you can buy LSD rebuilt off of ebay for under $200, thats what I did and have had no trouble as of yet...
You know that I'm going to recommend the Eaton posi. It's the best out there for most GM cars. A new one is $447 plus shipping. You need a set of bearings and shims to install it. You will also need a dial indicator with a magnetic base to set the backlash.
So just get the carrier or buy a whole new rearend posi?
I'm a little confused about some terminology but that link to the other thread did help a bit. What's a spider that you said was welded? And what is Powertrax?
I'm a little confused about some terminology but that link to the other thread did help a bit. What's a spider that you said was welded? And what is Powertrax? Supreme Member
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
A spider is an internal gear. It doesn't "gear up" or "gear down", it's simply 1:1. It allows the left or right to turn independently, such as turning a corner...
Welding them together forces left and right to turn together - all the time. Turning a corner is harder (chirp, chirp chirp!), but straight line traction is best.
Powertrax is a brand of posi. It's a limited slip unit (limited slip=posi) that is installed in your existing OPEN carrier.
A carrier is what you bolt your ring gear to. It's the "center chunk". The carrier can be an open, limited slip (of any variety, worm gear style like a torsion, clutch style like an eaton, gear style like a Detroit locker) or it can be a spool. A lincoln locker is a homemade spool.
Putting a "mini spool" inside your open carrier is also possible. (A non-mini spool is the entire carrier).
Hope that cleared things up, rather than the other way around. Lots of info on the net though, keep researching!
oh, I almost forgot to give my opinion! Detroit true trac. It's another flavor of posi. It's a worm gear style, like the Torsions that some 4th gens got. It's only about $380 or something, and has no clutches to wear out. Same install as an Eaton clutch style (still have to re-set up the gears).
they say a picture is worth 1000 words right????
This is an open diff, the diff case is also called the carrier
this is a powertrax, it goes inside the carrier you got
This is an LSD (posi) carrier notice the springs and clutchs, this allows it to lock up (twin tire fire) but also allows it to "slip" around turns
this is a mini spool, it goes inside the carrier, this gives you full posi, both tires all the time, this is the same as welding the spider gears, not really for the street
and here is a full spool it replaces the carrier and you got this attached to your ring gear
i hope this clears it up for you and put some pictures to the words we talked about
I think everybody knows how dangerous a Lincoln Locker is. Welding a heat treated gear makes it brittle. If the axle gears break then the c clips will come off of the axles and the axles and wheels will leave the car. I have seen it happen.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I don't agree about everybody knowing it's dangerous. Many have heard of it, but when I explain, these people don't believe just one guy saying so. The few I've talked to about it later have all, without exception, gone in search of other opinions. Probably happened a few times to any automotive machinist. So many teens just getting started in this hobby, we hafta try to stop them from trying this.
You are right. I have run into the same problem with spools and mini spools. People don't understand how dangerous these things are on the street. Not only to themselves, but to other people who share the road with them. Might be my wife and kids that they kill when the axle and wheel come out.
Car: Iroc-z
Engine: 305tpi
Transmission: 700 r4
Axle/Gears: 2.73 (poor)
So following up all this I live over in England and my thirdgen has been giving me posi ache (understatement). Basically I wrecked one 2.73 posi and after having it rebuilt it started clunking again. Opened it up and sure enough one of the clutch plates has been cracked and the metal pushed out by one of the springs in the corner. So anyway I've got myself a 3.23 open rear end in great nick but I just cant live with a one legger (espescially as i have nitrous.)
My question is where can I get a mini spool from and lock it? Ive welded several posis before on small powered cars where they shouldnt and havent broken, but I dont fancy doing it on a third gen. How safe is a mini spool? Obviously getting parts for me is tricky so I dont want to get an eaton, detroit etc and have that break on me.
What would you guys do? 3.23 open ender, but want it locked on a budget. cheers guys.
I don't think you would ever have any problems with the Eaton. If this is a race car then the spool would be all right, but not in a street car. The little 7.5 rear end isn't strong enough to handle much power anyway, so anything that you put in it is subject to break.
Car: Iroc-z
Engine: 305tpi
Thanks for that i knew you'd be the man to help. I basically have 2.73 gears pretty stock but I run nitrous so that could grenade it. Ive got the 3.23 axle so that'll help put more force on the tyres :-). So ok for racing but not street? Just quickly is that because it's considered a handfull to drive on the street with rampant understeer? Im fine with it being a handful just not fine on it grenading. And ok ok a few doughnuts in the past never helped my axle lol.
I've seen cars with spools on the street that broke all of the studs off of an axle, broke axles, cracked wheels and other things. A spool puts a lot of stress on parts when you have to turn corners a lot. If you want something stronger I can fix you up with a Moser 12 bolt. I know shipping is a big expense for you, but you won't break any more rear ends. I've shipped these all over the world.
Car: Iroc-z
Engine: 305tpi
yeah something like that is ultimately what i need. shipping, import tax all that adds up, oh and the dollar rate. How much do you charge and what's the spec of the axle? I would prefer a good reconditioned axle which bolts straight in. Some sub frame connectors wont go a miss either lol
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Please verify
https://www.thirdgen.org/1985-chevy-camaro
JamesC
Thanks JamesC for the link. I have a specific question and I did a search and couldn't find a thread that addressed my specific problem.
All of a sudden my sons car started making a clunking sound and actually slips during take off. After tightening the rear tranny mount, and inspecting the drive shaft and looking at the rear end area, everything looks fine. It sounds like the rear end is missing a couple of teeth and is slipping when those missing teeth get around during take off. This only occures during take off. Would it be easier to replace the whole rear end or just the gear?
Or, am I way off base and it possibly be something much simpler?
I also noticed a glaze covering the differiental as if to suggest the grease has leaked all out.
I'll take the diff cover off tonight and inspect it.
Any suggestions would be most appreciated.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
turning on wet roads was pretty interesting in that car.
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
i don't recommend a spool for a street car...i got a rebuilt posi unit and got it installed by a pro ,,,not really expensive .. there are auburn's ,,and eaton being really great units ,,just be careful of the spline count in your car ,,,the axles and the posi unit you need for a 1982-1988 camaro/firebird is with 26 splines ..and 1989 to 1992 you need 28 splines....as for the rest ..i kept my ring gear off the open rear and installed on the new posi without removing the pinion gear,,then he installed it and adjusted it and filled it up with new fresh oil.. now i find it takes off quicker and i have 2 tire marks!....good upgrade...
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
novaderrik
Aug 10, 2015 12:44 PM
